Really the Front Brake Discs are worn at 33,000 km ? That's atrocious !
Last SUV the original Tyre's, Pads and Discs lasted 80,000 when I sold the car
This will be the last VW I buy if my Brake Discs need changing at 33,000 km
Printable View
That sounds nuts. Pay $60k for a new car to change the brake pads as you get the car delivered because the company puts crap pads & discs.
If my VW Tiguan Brake Discs only last 33,000 km, seems like I will need to go back to the Koreans where this nonsense is not needed.
2021 Genesis GV70 revealed: Luxury medium-sized SUV bound for Australia | CarAdvice
https://www.youtube.com/watch?v=tUEtRRDY2IE<br>
279kW/530Nm 3.5-litre twin-turbo petrol V6 (0-100 km/h in 5.1 seconds)
224kW/422Nm 2.5-litre turbo petrol four-cylinder (0-100 km/h in 6.1 seconds)
All matched with an eight-speed torque-converter automatic
In Australian showrooms the first half of 2021
USA RRP $40K
I can understand your frustration, but I believe it is to do with allowing the brakes to operate in very cold climates as well as having good braking performance for high speed (eg Autobahn) driving. We need neither of these features here in Australia, so you spend a few hundred dollars fitting more suitable brake pads and you get longer lasting and less dusty brakes.
As much as it seems crazy to change the brake pads on a new car, the upfront cost will work out cheaper for you in the long run as you will not be replacing pads and disks after a few years, let alone the money you will save on wheel cleaner sprays.
If $300 of pads and rotors is freaking you out then it's best you stay away as you won't like the other costs either.
The pads and rotors are a Euro thing. They are designed not to squeal and to bite in -30c temperatures and pull the car down from 200kph down to zero several times without waving the white flag. The price for that is lots of dust and regular pad/rotor changes.
I consider myself a pretty docile driver and certainly coast up to lights rather than braking hard at the last minute.
I learnt the hard way nearly 20 years ago in my first Pajero. Again front brakes @ around 40k
Big heavy 2.2t driving it like I was driving a Corolla.
I ended up selling it with 120k on the clock and still on that same set
