Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 65
Thread: Brakes shot at 45k
  1. #31
    Oct 2017
    Coburg North, VIC
    Don’t panic, tell them you come when your brakes are really due for replacing. There’s the brake pad wear indicator that will light up on the dash. When that happens there’s usually 3mm friction material remaining on the pads.
    Yeh, too late for this service but I'll be more mindful next time. I don't really trust the VW service centre I went to so definitely won't be taking my car back there again.
  2. #32
    Adelaide hills, SA
    Quote Originally Posted by Simonr23 View Post
    What about disc wear?
    I can see my front discs have already worn about 1-1.5mm in 22000kms.
    Haven’t checked the pads yet (or looked at the brake reservoir)
    Not a big deal, they’ll get replaced with the pads.
    More you use brakes and harder you go on them, less they last you.
    I did 2018 Tig last week, young female driver and she done over 60,000km on front brakes, rear still at 4mm remaining.
  3. #33
    Apr 2017
    belgrave victoria
    I had ate ceramic brakes fitted from pretty much new on my Alltrack
    Just about to hit 60,000k service and they still have heaps of meat left on the pads and the rotors don't even look worn
    I will definitively use this combination again much impressed
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
  4. #34
    Jul 2020
    australia
    Hi all, anyone recommend where to buy disks & pads in Perth, 2017 tiguan rline ? whoever fitted the last ones, pads are overlapping the disks (front)
  5. #35
    Jul 2020
    Whadjuk, Kwoppa Keppa / Fremantle Western Australia
    what do you mean by overlapping?
    2018 Tiguan Allspace TDI DAP+S&V
    2010 Mazda RX8 GT
  6. #36
    Jul 2020
    australia
    the pads are overlapping the edge of (the outer edge)disks almost like the pads are too big.
  7. #37
    Aug 2018
    So my brakes just started to “squeal” yesterday, on light applications
    I have done just under 30k kms and service was done about two months ago
    Is this an audible warning that the brake pads will need replacing?
    And is it likely I’ll need new discs as well?
    Or can I get them machined?
    2018 Allspace 162TSI R Line
  8. #38
    Oct 2015
    For a free/easy answer, you’re going to have to look at them.
    Brake pads are a bit hard to get a good ‘eyeball’ result with the wheel on. You may get lucky with a torch, gaps in the wheel, your own head angle.
    Discs are harder to determine, but easier to ‘eyeball’.
    If you can feel/see a ridge on the outer edge of the disks, and it’s more than a mm in ‘height’ it’s probably new discs. If there’s no ridge, you may not even need a skim.
    Also check for any tracks on the disc surface. Sometimes a stone/metal item gets stuck in the pad/disc area and gouges out its own channel- again, if it’s deep, new disks. If shallow, or nothing there- as you were
  9. #39
    Sep 2011
    Melbourne, Victoria
    I just replaced by front rotors with DBA 4000's and pads to ATE ceramics at 45,000km service.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  10. #40
    Quote Originally Posted by iDiesel View Post
    You can try getting your pads re-seated with some grease behind them. This may stop the noise.
    There's no audible warning with the stock pads - though there is a pad wear indicator and this will set off a warning light on your dash. It's just more likely you have some road debris stuck in your pads that has caused groves in your rotors and end result is a bit of noise.
    If you can run your finger across and feel that your rotors are not smooth you could look at getting them machined. The smoother the rotor, the less noise.
    Generally change discs and pads at the same time, though with 30k on the clock you shouldn't be needing this early.
