Results 1 to 10 of 18
Thread: Active Info Display issue with Nav screen
portas1971 Active Info Display issue... 02-08-2018, 02:51 PM
Pointcookie I think what u need to do is... 02-08-2018, 02:54 PM
portas1971 I will try that but normally... 02-08-2018, 02:59 PM
Shaqattack Yeah i remember that pressing... 02-08-2018, 03:47 PM
portas1971 Thanks guys. I am normally... 02-08-2018, 03:55 PM
Shaqattack Al good mate! Now as... 02-08-2018, 06:40 PM
portas1971 $1180 for ‘special’ which... 02-08-2018, 07:40 PM
Crous26 Active information display... 06-01-2019, 11:30 AM
Crous26 Can you help 06-01-2019, 11:31 AM
Simonr23 Can you post it in English,... 06-01-2019, 12:02 PM
tigger73 Updated with google translate 06-01-2019, 12:47 PM
Crous26 Active info display is not... 06-01-2019, 07:03 PM
Lindsay Simple answer: The Active... 06-01-2019, 08:14 PM
Crous26 Available in other vehicles ... 06-01-2019, 09:01 PM
Simonr23 I can’t be certain of this... 06-01-2019, 09:25 PM
Rooboy All he's doing in the video... 06-01-2019, 10:01 PM
Crous26 my car does this ... 06-01-2019, 11:37 PM
Crous26 Can you help me ☹☹ 14-01-2019, 08:18 AM
    May 2018
    Melbourne - Eastern Suburbs
    Had this issue for a day now and it’s driving me crazy.
    Basically when I scroll across the Active Info Display screen to show the Nav screen, the tacho and speedo don’t resize smaller and the map size doesn’t increase like it should and used to.
    I have forced restart holding power button down on Discover Pro and also cycled ignition various times and still won’t resize.
    MY18.5 Tiguan - R-Line/DAP/Sunroof in Tungsten Silver
    Jul 2018
    I think what u need to do is push the OK button on the right side on the steering wheel when u see the map(this is what i need to do anyway)
    Sent from my SM-G955F using Tapatalk
    May 2018
    Quote Originally Posted by Pointcookie View Post
    I will try that but normally you just select Nav and after a few seconds it should resize and accept Nav without pressing OK.
    Jul 2018
    Yeah i remember that pressing the ok button zooms on the display to the map
    May 2018
    Thanks guys. I am normally tech savvy. Have taken a break at work to check. All good now.
    It seems that by pressing OK, it toggles auto resize on/off. Thanks for your replies and expertise.
    Jul 2018
    Al good mate!
    Now as thanks you need to post some photos of the tigger!
    Edit- just seen the little beauty.
    How much did you pay for ceramic coating?
    May 2018
    $1180 for ‘special’ which included coating plus wheels and windscreen/rear window treatment.
    Jan 2019
    Eskisehir
    Active information display help
    Active information display;
    shows radio stations, but the radio
    shows the song played but does not show the song list
    Could it be a problem?
    Also:
    arrow button does not zoom the map
    song does not appear as a list
    radio does not appear as a list
    How can I solve
    Address 17: Tools (J285) Tags: | 5G0-920-XXX-17.clb-SRI3
    Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
    Component: KOMBI 407 3195
    Coding: 07AD0018FF8C000801886B0B1000000000000000
    Shop #: WSC 01545 995 12345
    ASAM Data set: EV_DashBoardVDDMQBAB 009.058
    ROD: EV_DashBoardVDDMQBAB_VW48.rod
    VCID: 29619B41486CBD02A2-807C
    Address 5F: Information Selection. (J794) Tags: * None
    Part No SW: 3G0 035 045 A HW: 3G0 035 045
    Component: MU-HN-RW H42 0343
    Serial number: A601J0FB001330
    Coding: 0284010AFF00000051110001000908001F0106E401200000DE
    Store Number: WSC 12345 123 12345
    ASAM Data set: EV_MUHig4CGen2HBAS 001001
    ROD: EV_MUHig4CGen2HBAS
    001001 ROD: EV_MUHig4CGen2HBAS
    Jan 2019
    Eskisehir
    Can you help
    Oct 2015
    Can you post it in English, please. That is the first step. Maybe help can be given
    I understand which modules you are in, but the rest appears to be in a language other than German/English.
