Did you have the traction control turned off?
Sounds like traction control stepping in, happens on all 4wds no matter the size. It must be turned off every time you turn the car off and back on again as it automatically comes back on
Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
[QUOTE=Oz85;1277537]Did you have the traction control turned off?
My understanding is it was switched off, as soon as you put it in off road mode you get a warning that traction control is off, mine doesn't have a physical switch. but i would also assume that is what is happening.
At the end of the day it was all good fun, had a good laugh with the group of people i was with, apparently it looked pretty cool with all the lights on and jets of sand in shooting in the air - something like the fountain shows out the front of a Vegas hotel and am happy to know the limitations of the system. but i don't regret getting the car, its still a pretty good rig on the road the tech, price, performance, meant it was a no brainer when we cross shopped it with a Discovery Sport.
Side note - when we were back on the road we had to stop and clean the sand out of the inside of the rims - about a 2cm build up I'm places, which really had the wheels off balance.
Hi DPS, this occurs with all automatic transmissions, not just VWs.
Also, if you are spinning wheels, try selecting a HIGHER gear.
There are a number of benefits of doing this. First, you have a greater control of the accelerator peddle which means your are less likely to spin the wheels so quickly and you can control the motor at a much lower RMP, again, giving you better control of your wheel slip, if it occurs.
No one really lol
Wife is pretty good, as long as I'm doing anything silly on private property or on a race track, I get to sleep in the bedroom not the couch
In saying that, I might change the Haldex settings soon and report back. Might be doing a weekend trip soon and hitting up some offroad areas. Will report back on how much sand in the air and wheelspin I can achieve
Thread bump. Thinking of taking mine on to the beaches around South East Queensland over summer but not keen on using the standard 20 inch tyres.
Does anyone know what other VW/Audi wheels will work? Thinking I might pick up a set of older 17s and put some meatier tyres on.
Doing this to stop from buying another 4x4! Want to try the Tiggy to see if it will work for basic beach driving and basic off road before spending more $$ on another car.
Great! What size tyres are you using and do you have any pics of the wheels fitted?
Edit: Just found your other posts with the info and pics. I wonder if all the Mk2 Tiguans have the same front brake size?
I've located a set of these wheels, could grab them to test fitment over the brakes before putting tyres on them.
