Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: battery power drain + Reverse Camera problem
    May 2020
    battery power drain + Reverse Camera problem-screenshot_20200812-203159_obdeleven[1]-jpg
    this is the fault code im getting. mechanic thinks all the code is gone.
    do you guys think re coding by my self will be possible? with right guidance?
    May 2020
    Did you clear the fault in the module OK
    yes there was no problem at all.
    Pacific Paradise QLD
    Dealer time I think I wouldnt be playing too much if it says it has lost data.
    The dealer can actually access the factory settings for your vehicle and set it back to them.
    Will cost about $250-300 apparently
    May 2020
    OK guys now i have fixed all my reverse camera!!!
    check this page out
    Activate rear view camera (OBDeleven coding) - OBDEleven - VWROC - VW R Owners Club
    Rear view camera | OBDeleven
    Highline reverse camera, as coding to get all the options is different from lowline with less options
    Lowline
    Highline (notice the buttons on right hand side to change camera angles/parking space)
    Make sure 5F-long coding-byte19-bit4 is set to not active
    Go into 5F adaptions
    Car_Function_List_BAP_Gen2:
    VPS_0x0B:
    activated
    VPS_0x0B_msg_bus:
    Comfort data bus
    Then depending on what buttons you have missing go into 6c-long coding
    correspondence_HMI_RV_mode_1
    correspondence_HMI_RV_mode_2
    correspondence_HMI_RV_mode_3
    correspondence_HMI_RV_mode_5
    4 and 6 give you function not available
    i could not find code above so i skipped but it still worked
    but for others im not sure.
    i've sort it out using this way.
    i think highline models and lowline models function is little different.
    i found out that some how i manage to put my rear view camera function to lowline model so it did not show anything just black screen with out any guide lines or functions. so i have used above method and worked with me perfectly.
    i have 2018 tiguan 163 highline.
    hope this will help people out with similar problems.
    Aug 2018
    Does it also depend on whether you have 360 view option vs not?
    2018 Allspace 162TSI R Line
    May 2020
    Quote Originally Posted by iDiesel View Post
    im not 100% sure if that matters but there is drop down option with ops display and ops360 display option try both and see if it works.
    if you look at the site above there is a option for reaview camera also environment camera (not sure what it is) and jap version or something.
    i tried both rear view camera and environment camera option but worked fine.
