Results 1 to 10 of 10
Thread: Auto On Off Disable button not working
    Dec 2020
    Hi All
    I have just bought a second hand Tiguan, 2017 Allspace.
    What I have noticed is that the disable auto on off button doesn’t work on pressing, or if it does only holds for a few stops then reverts.
    Is anyone familiar with this problem, or any fixes?
    Aug 2018
    Is it an Allspace or SWB Tiguan?
    Allspace came out in 2018
    Maybe the previous owner changed the settings on the stop/start?
    2018 Allspace 162TSI R Line
    Pacific Paradise QLD
    Quote Originally Posted by iDiesel View Post
    Can only change it to always off
    Dec 2020
    Sorry it bad, it’s a MY17 Trendline.
    Dec 2020
    Nope it’s definitely on. The button is intermittent. And sometimes when you can disable, it lasts a street light then it goes back to auto on off.
    Quote Originally Posted by Uprev View Post
    Faulty switch maybe Either that or check the battery level. Strange things happen with VW when the battery is on its way out.
    Dec 2020
    Wierd huh. Measured 12.6V on the battery so seems okay. Will probably take it somewhere to get checked out as it is really annoying.
    Any recommendations for Syd?
    Yeah auto stop/start doesn't operate when the car senses the battery state of charge is not sufficient. This is also the case when it needs to run the A/C on full it won't stop the engine because the load on the battery would be too much.
    Dec 2020
    mate, auto stop/start works. thats the problem. what doesnt work is the button that disables it for the remainder of the ride.
    Dec 2020
    As an update FYI - I took it to VW Service.
    Fault wire into the button caused it to not turn on/off the auto on/off disable.
    Quick fix!
