We’re still waiting for someone to do the before and after dynos to verify the APR (or any other tuner) claimed values.
APR tunes typically are aggressive at lower RPM and tend to fall off towards Redline. It’s just the way they approach tuning and you will likely feel that at’s running out of steam in the last 1,000rpm. If you look at their published dyno charts it shows this quite clearly what you’re feeling on your butt dyno:
Different tuners will do things differently and look to pull all the way to Redline but less aggressive early. Different schools of thought and approaches to tuning.
The APR claimed increases are based on the VW published figures (which are conservative numbers) and on a “calculated” engine power. It is my belief that the stock VW number is low as they publish a curve with the “nominal” engine power for the motor and not “actual”. The APR figure is not easily verifiable as their figures are flywheel numbers and are calculated using drivetrain losses which are estimated. Personally I don’t like this approach as I’d rather real world before/after dyno at wheel figures on a real car but it seems a lot of major tuners do this which makes verifying marketing claims almost impossible. Fuel quality will also come into it but that’s another topic completely.
My own personal experience running my 162TSI on the dyno is that stock it is putting out close to 180-185kw at the fly (140kwaw on the dyno). Therefore even if you get the 235kw flywheel figure APR claims, that’s around 67hp (not 7
increase from stock.
Plus the biggest difference between stock and stage 1 is at ~5,000rpm and after that the APR tune increase to stock drops off.
Only way to fix this is to install an IS38 turbo
