Originally Posted by
Dose Pipe Sutututu
Let's use your results as an example, 162kW motor, 140kW output (rougly). That equates to a 15% drivetrain loss (not bad for AWD).
So.. if Revo or APR or any flash jobby say claims 235kW at the motor, that should equate to 200kW at the wheels.
Always good for a healthy discussion
So with the standard engine it "loses" 22kw but with the tuned engine it "loses" 35kw. Same gearbox, same diff, same drive shafts etc. So where does the extra 13kw go? It just disappears? Magically? Some guy called Newton (remember High School Physics) worked out that energy can be neither gained or lost, but it can be transformed into other types of energy. So what is the extra 13 kw transformed into? Heat, I don't think so, stand in front of 13 x 1kw heaters, that's how much extra heat we would be be talking about.
There is some logic is taking the constant kw loss, not a %. So 235kw on the engine dyno should be (235 - 22 =) 213kw on the rollers.
FWIW using a hub dyno results is less "loses" due to absence of tyre and roller friction, so I always expect to see a higher number on the hub dyno that what I see on the roller dyno (for the same engine output).
Gary
