Results 1 to 10 of 13
Thread: Annoying dash vibration
    Aug 2017
    Vic
    So I’ve got an annoying as feck dash vibration
    I feel as if it’s actually behind the digital dash panel somewhere
    I’ve pressed down on most of the plastics when it’s happening inc the dash panel it self, and nothing seems to suppress it
    It’s at a certain rev and rpm, often at cruising speeds or coasting down a hill where it can be constant and annoying for a period of time.
    Anyone else had or have what they think maybe is the same?
    I don’t think I’d be game to start dismantling to get behind the dash
    Have read this I will have a look to see if this is maybe it, I don’t think it will be though as this noise is right in your face and is quite apparently there as you move your face closer to the dash, I wouldn’t have thought it would be come from over near the glovebox side
    Annoying rattles - VW Tiguan MK2 Forums
    This one closer to the mark maybe where he speaks of the high frequency buzz
    Active info display occasional rattle.. - VW Tiguan MK2 Forums
    Aug 2018
    I don't have a rattle, but notice a buzzing when using ACC and as the car slows down - like a servo motor applying pressure on the brake master cylinder
    Car has to be dead silent (i.e. smooth road, windows up and no radio). Seems to come from behind the active dash
    2018 Allspace 162TSI R Line
    Oct 2018
    Melbourne, VIC
    Record a video so you’ve got proof, then take it back to the dealership (if you’re still under warranty)
    Oct 2015
    Mine had a rattle in/behind the AID. They ended up replacing that whole piece. I’m assuming there was a broken clip somewhere during the build process.
    Aug 2017
    Vic
    Simon why was it replaced? Not because of the rattle in assuming
    Oct 2015
    Yeah it was. As I mentioned above, I think (never told why) it was a broken clip on the AID assembly causing the annoying buzz/rattle. The AID itself worked fine.
    Aug 2017
    Vic
    How did you get them to look at it? Took a tech for a drive and got it to mimic the noise?
    Oct 2015
    Luckily, they could easily replicate the buzz- I gave them a thorough description of how/When it happens.
    Possibly they broke something when pulling it out to put some foam behind it?
    They have scratched bits of the new cluster- tiny and haven’t bothered complaining. It was too long after install to prove it was them.
    scratched and greasy hands the a, b and c pillar trims(during sunroof lights work(replaced after I called them on it)),
    Scratched/broke the central dash fascia(admitted and done as it happened- without me complaining)
    left the hazard switch unplugged(I didn’t notice at first, but they happily fixed when I called up and dropped in the next day)
    Mar 2023
    ACT
    Hi smarty, did you ever the get your issue resolved, and if so can you share the fix? I have recently picked up an Allspace Adventure and have similar issues to what you have described. Be keen to get any ideas before I start the fun with the dealer.
    Pacific Paradise QLD
    My Passat had that and I pulled the panel out and put some foam behind it and also some thick tape on the clips to hold them in better. Fixed it ok
