Sure did
They traced the vibration to a loose drivers knee airbag or something
Soon as they tightened that up noise disappeared
Been perfect ever since
A different issue and vibration rattle I also had fixed was the common fuel rail one too but that wasn’t all that audible inside the car, not like the behind dash vibration
I had the buzzing sound at around 2000rpm, noticed when did a test in revving in neutral and also when coasting downhill and also when taking off from stand still. Could hear the buzzing from front of dash and driver’s side door. Tech at VW knew the problem when took it for a test.
The fuel lines run under the driver’s floor and were loose, they put cable ties and insulation around it and the buzzing is now gone. The flow of fuel when revving would cause them to vibrate and noise would travel up side door.
Yep I also had the fuel line rattle fix done to mine too , firstly when they were trying to find the rattle but it didn’t end up being the fuel lines that were causing the buzz. Process of elimination
- You may not post replies
- You may not edit your posts
Forum Rules
