Results 11 to 20 of 26
Thread: All Terrain Tyre options for latest Tiguan (2018 Wolfsburg Edition)
    Jun 2011
    However putting smaller rims with higher profile tyres doesnt change much as the overall diameter is almost identical It was said earlier in the linked thread that the 17s with higher profile are about 2% larger, which surprised me but that is acceptable.. Much more than that wouldnt be
    For Nsw the ruling is no more or less than 7%
    We’re not talking extreme lifts here, just more compliant tyres for off-road use. The car has 20” 40 profile which would be horrible on rough roads and more susceptible to damage. 17” 65 profile is gonna add a lot more cushion and the right tread and sidewall thickness will add security for punctures.
    Oct 2015
    Agreed, but I hope everyone realises that the profile is a percentage of tread width. So 65% of 215mm is less than 65% of 245mm. About 20mm difference on each side of the tyre, so approx 40mm total. That’s not a small amount(maybe still legal though- if 7% is the rule)
    Jun 2011
    Quote Originally Posted by Simonr23 View Post
    The 7% applies to the diameter compared the OEM tyre. Width doesn’t come into it regarding the ruling however width is a factor in the overall diameter measurement. So as long as your overall is under 7% smaller or larger than a placarded OEM rim and tyre combo your sweet. (Rubbing is a separate issue however and must still be checked.
    https://www.rms.nsw.gov.au/documents...eels-tyres.pdf
    Pacific Paradise QLD
    In QLD the Tiguan can have tyres 15mm LARGER Diameter or 26 mm SMALLER diameter.
    An MC category vehicle like a Landcruiser etc can have tyres up to 50mm large diameter or 26 smaller diameter
    A Tiguan is classed as an AWD softoader and is NOT an MC category vehicle
    From the ADR rules
    Section LS Tyres, Rims, Suspension and SteeringVersion 2.1 –1 November 2015 Page 20/LS804.2.4
    Overall Nominal Diameter
    The overall diameter of any tyre fitted to a passenger car or passenger car derivative must not be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that model.
    Jun 2011
    From the ADR rules
    Well that changes the game a bit. 711mm is the diameter of the 255/40r20
    225/65 R17 will get in just under the 15mm increase.
    Yokohama have a GO15 in that size.
    Kumho AT51 also in that size.
    Cooper has the ATT in that size
    Or the AT3 in 235/60r17
    Oct 2015
    Maybe I worded my post strangely, for people not familiar with tyre sizing. Sorry if that’s been the case.
    Quote Originally Posted by Foxpuppet View Post
    Rules often do rather than misread opinions LOL
    Erskineville, NSW
    I'm extremely familiar with tyre sizing and tyre/rim packages and your post made very little sense...
    Mar 2019
    Green Point, NSW
    Hey, thanks for the input. I'm not familiar with those measurements you noted sorry but basically the stock wheels currently on the car are 255/40 R20. So I think as long as the brake clearance is fine, I should be able to fit ie. a genuine 18" rim from VW and fit a 235/55 R18 on it or so. Do you think 17" would be better? I had the Yoko GO15s on my Forester before and yeah, great tyre!
    Quote Originally Posted by tlenzenh View Post
    Heres the truth You can only go 15mm larger diameter or 26mm smaller.
    What happens if you do
    Larger your speedo will read slower than it did before.
    You should check it now against a GPS to see what it reads at 100kph and will possibley read as high as 107.
    So a slightly large diameter will bring it closer to correct.
    Gearing will be slightly higher so slower off the mark Braking not quite so good
    Smaller diameter Speedo will be wildly out and show a much faster false speed
    Braking will be better and will be faster off the mark
    You can check it here as its a really good comparator Can alter sizes and also offset etc.
    Will give speedo differences as well
    Custom rims, wheel tire packages
