Results 1 to 10 of 12
Thread: Air con smelling
    Aug 2017
    Vic
    Air con smelling
    Hey guys
    My air con absolutely stinks when you use it and only goes away after a long time of running.
    There’s about ~28,000kms on it
    I’m assuming it will be a dirty pollen filter or something from what I’ve read about other VW models?
    Are these changed at each service and tend to tire towards the 15,000km mark?
    Is there anything I can realistically check or easily change? or is it just a drop off at VW job
    Air con smelling
    Just get it changed at your next service if it’s due at 30,000km.
    Likely they only changed oil and oil filter at 15,000.
    May 2018
    Melbourne - Eastern Suburbs
    Or you could DIY and try one of these superior filters Air con smelling
    Cabin Air Filters | Volkswagen Tiguan Cabin Air Filter 2016-
    MY18.5 Tiguan - R-Line/DAP/Sunroof in Tungsten Silver
    May 2007
    Quote Originally Posted by portas1971 View Post
    Interesting looking Cabin Filters...
    Aug 2016
    Sydney NSW
    Quote Originally Posted by smarty View Post
    Hey guys
    Funny you mentioned this, my family started noticing this recently too - on my Oct 2016 Tiguan.
    In my case, it smells sort of sourish almost like vinegar....is yours like that?
    Aug 2017
    Vic
    Yep mines more of a putrid smell though
    Jul 2018
    The foul smell is usually just mold or bacteria in a filter, but can be more problematic if it occurs elsewhere in the aircon system.
    Nov 2013
    AUS
    Do you guys run the air con all the time + recirc?
    I used to and it caused a bit of a funny smell.
    I ended up replacing the air filter and turned off the recirculation memory so that it runs without it unless I turn it on.
    So far haven't had the smell return
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
    Oct 2010
    Perth
    Been waiting for someone to post this on here. Yes, my friend the other day gave an absolutely brutal complaint about the smell of my air con and said I was too nice to not force the dealer/VW to fix this under warranty. My car has only done about 18000 KM and when I recently took it to the dealer for an investigation, they had absolutely no idea and wanted to remove the passenger seat and carpet to access the drainage pipe. They even asked if any babies have vomited on the seats (leather seats which are apparently vomit proof but of course dealers would have no idea) or pets peed or pooed on them but they definitely never happened. This previously happened with my Golf GTI MK6 which the dealer only masked the smell of each time I took it in for a service. I have even inspected the cabin air filter myself and had a good long sniff at it but didn't smell anything remotely similar to what the air-con emits. The cabin filter replacement schedule is usually every 24000 KM but depending on where/how you drive your Tiguan may need to be replaced earlier. I live in the suburbs and drive my car mainly into the suburbs for work, parked outdoors at work but under the garage at home. I have another car, Hyundai Getz purchased in 2009 and the air con has never produced such a stench in all those years.
    After a bit of research I went out and bought AutoGlym AirCon Cleaner which had an immediate impact, even when the air-con is turned on each time. However, you may need to use a couple of these to totally get rid of the smell, maybe not for good, so you may need to repeat the self service clean every 12 months. Maybe send the bill to VW. If we have enough people doing that, we can kick up **** storm and get consumer protection involved.
    Aug 2017
    Vic
    It’s due for the 30k service in 1,400 km so I will give them heaps about it when I drop it off
    The more I read about it though the more articles you find about peoples VWs with smelling air cons which is annoying.
    Well if it’s meant to be changed at 24k maybe it did start smelling then and has progressively got worse, essentially it’s almost done about 25% more than it’s assumed life span before needing to be replaced.
    And something like that should then be changed with every service, then it would never be a problem. How much are these filters as a consumable anyway?
