I think what u need to do is push the OK button on the right side on the steering wheel when u see the map(this is what i need to do anyway)
Sent from my SM-G955F using Tapatalk
Had this issue for a day now and it’s driving me crazy.
Basically when I scroll across the Active Info Display screen to show the Nav screen, the tacho and speedo don’t resize smaller and the map size doesn’t increase like it should and used to.
I have forced restart holding power button down on Discover Pro and also cycled ignition various times and still won’t resize.
MY18.5 Tiguan - R-Line/DAP/Sunroof in Tungsten Silver
Yeah i remember that pressing the ok button zooms on the display to the map
Thanks guys. I am normally tech savvy. Have taken a break at work to check. All good now.
It seems that by pressing OK, it toggles auto resize on/off. Thanks for your replies and expertise.
Al good mate!
Now as thanks you need to post some photos of the tigger!
Edit- just seen the little beauty.
How much did you pay for ceramic coating?
$1180 for ‘special’ which included coating plus wheels and windscreen/rear window treatment.
Active information display help
Active information display;
shows radio stations, but the radio
shows the song played but does not show the song list
Could it be a problem?
Also:
arrow button does not zoom the map
song does not appear as a list
radio does not appear as a list
How can I solve
Address 17: Tools (J285) Tags: | 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 407 3195
Coding: 07AD0018FF8C000801886B0B1000000000000000
Shop #: WSC 01545 995 12345
ASAM Data set: EV_DashBoardVDDMQBAB 009.058
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 29619B41486CBD02A2-807C
Address 5F: Information Selection. (J794) Tags: * None
Part No SW: 3G0 035 045 A HW: 3G0 035 045
Component: MU-HN-RW H42 0343
Serial number: A601J0FB001330
Coding: 0284010AFF00000051110001000908001F0106E401200000DE
Store Number: WSC 12345 123 12345
ASAM Data set: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS
001001 ROD: EV_MUHig4CGen2HBAS
Can you help
Can you post it in English, please. That is the first step. Maybe help can be given
I understand which modules you are in, but the rest appears to be in a language other than German/English.
