Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 191
Thread: Accessories
  1. #21
    Pacific Paradise QLD
    Quote Originally Posted by shanelord View Post
    Looks like Westfalia Australia have their A40V available for the previous generation Tiguan with a 200KG ball weight. I've used them previously on my Audi Q7 and they are awesome.
    Product-EVTowbars
    I've reached out to see if they have one coming for the new gen 2 Tiguan as this may be the answer.
    Regards,
    Shane.
    Remembering that the allowable towball weight is set by the vehicle manufacturer NOT the towbar maker.
    Also no gain from putting a (say) 3000kg towbar on a vehicle rated at 2000kg.
    The ADR rules state quite clearly that the towing limits of a vehicle may tow either to the rating of the vehicle or the towbar WHICHEVER IS THE LESSER.
    Towball mass is set by the vehicle maker
  2. #22
    Apr 2012
    Kellyville, NSW
    Yeah I've since discovered this. I'm in discussions with VW Corporate via my dealer at the moment.
    I'm awaiting a statement from VW as I've challenged them to prove how they can in good conscience advertise a towing capacity like this where no 2500kg caravan in Australia is supplied with anything less than 6% ball weight.
    This is borderline misrepresentation/false advertising.
    Will let you know what they come back with.
    Regards,
    Shane.
    Sent from my Pixel XL using Tapatalk
  3. #23
    Regards,
    Shane.
    Well looking at it logically it is after all a euro built car and the number they sell here is a drop in the ocean in the scheme of things.
    Caravans in Aus are built out of step to the rest of the world and traditionally have been towed by 4x4 vehicles often with a weight exceeding the vans weight. Actually that is the ideal situation.
    Euro vans are built to different specs and generally are much lighter and by careful weight distribution achieve a lighter ball weight.
    They also incorporate ESC controllers to help braking and sway. This is gradually being introduced here but not as a rule of thumb in most makes..
    Therefore VW and others build for their mass market , which is only to be expected and if you want to tow an Aussie van buy something suitable. I have read the even Amaroks have given trouble towing, with dual mass flywheel problems and people towing in too high a gear and breaking things. Nissan X Trails had big problems with the factory towbar literally ripping out of the bodywork.
    Other makes also have foibles and it pays to do your homework BEFORE buying something you THINK may be suitable and then finding out its not.
    I know because it happened to me I bought a Patrol 3L auto and then found the van I bought was too heavy for it. Cost me another $23,000 to trade up to a Landcruiser. Nothing like weight, cubic inches of diesel and 145 L fuel tanks for towing my 25ft 3000kg van.
    Can your vehicle actually tow 2500kg as GCVM and axle weight limits have to be taken into account.
    That is the max allowable loaded GVM of the tug (including ballweight) and the rated GTM (or weight on the wheels only) of the van.
    To be precise at any one time it is the actual loaded weight of both which may not exceed the plated GVM and GTM and GCVM
    There is a lot more to it than just buying something and hooking up and going.
    Personally after driving a Tiguan loaner a couple of years ago I thought it was gutless in comparison to my Passat and too small and light to be towing a decent size van.
    Perhaps you should look at some of the Caravan forums. Has been some discussion on them on there about how they go or in some cases dont.
  4. #24
    Apr 2015
    The "European" towbar isn't certified in Australia (ADR 62).
    I use a Hayman Reese load distribution hitch to tow ~1700 kgs (race car and trailer). The tow ball weight (without hitch) is 160 kgs but the rear axle load is measured at 95 kgs as the hitch "moves" 65 kgs of load to the front wheels.
    Gary
  5. #25
    Quote Originally Posted by Sydneykid View Post
    Gary
    Are you really sure
    Product-EVTowbars
    And here from Westfalia site :- Westfalia-Automotive Australia bars meet the NZ Domestic Standard 5467 (1993) and Australia Design Regulations (ADR)
    Towball weight of a trailer is weighed DISCONNECTED FROM THE TUG.
    What a WDH does after you hook up is irrelevant.
    It is weighed like that because not everyone uses a WDH ( or needs to)
    You would have your hitch done up really tight to move that % of weight to the front wheels and I doubt it extremely.
    Normally it is less than 25% and can be checked like this.
    Measure height under front wheel arch then
    hook up and remeasure height from ground to under front wheel arch.
    Attach WDH and do it again. measure how far its dropped.
    Other way to check weights is weigh the tug Hook up weigh it again Do up WDH weigh it Will still be almost the same as
    previous weight because the action of the WDH applies more force to the joint and distributes some weight forward but in no way
    lightens it
    How can it. Would need a Jack under it or a skyhook to do that
    Other way is to weigh each axle before and after as above to confirm weight changes
    I spoke to HR technical services and they confirmed that fact.
    Also remember that the towball weight is part of the tugs payload so you cannot legally load tug to GVM and add a trailer.
    After a few years of full time vanning with a heavy van and reading up on staying legal I can assure you what is written is on the button
    Yes your rear axle weight will alter but it will be a lot more than 95kg even in an empty car.
    Unless you mean it will increase by that amount with the WDH hooked up
    Most would have a rear axle weight limit in the area of 1200-1900kg depending on the model
  6. #26
    Apr 2012
    Kellyville, NSW
    While I agree partially with this, Australia, like NZ, follow the USA methodology of 6-15% as ball weight.
    If you are advertising a car in Australia, misrepresentation or false advertising is when a reasonable person based on available information would be misled.
    In this case VW Sales staff, VW brochures and VW website advertise 2500KG towing and don't detail the 100KG ball weight.
    The reasonable assumption IMHO for most people would be then that the manufacturer would advertise to suit the local environment, and 2500KG would be realistic based on the towable caravans or trailers in the local market.
    We can agree to disagree on this; but until I found this detail on these forums, I was misled.
    Regards,
    Shane.
  7. #27
    Regards,
    Shane.
    The ball weight is available, you should only have to ask or read the manual. I thought it well known that Euro cars almost all have a very light ballweight limit. Every vehicle has a limit on this, including heavy 4x4. Eg a Pajero can tow 3000kg but above 2500kg has a reducing scale of ballweight as does a Patrol.
    Solution is buy a Bayley or a Jurgens or a York van and that will go a long way to solving the problem.
    Unfortunately "assuming" something rarely turns out good as I also found out. After that I did due diligence regarding weights of both parts of the rig.
    Failing to tell you the answer to an unasked question is hardly misrepresentation.
    In the brochure for my Passat it has a section regarding weights including the ball weight so it is available before you buy.
  8. #28
    Apr 2012
    Kellyville, NSW
    It's not in the brochure or on the website for the Tiguan.
    It's also not common knowledge (The VW Dealership owner is in agreement with me on this - he's working to clarify with VW Corporate).
    Regards,
    Shane.
  9. #29
    Regards,
    Shane.
    Strange how they publish some and not others. However if buying with the intention to tow a van it is advisable to ask that question, as you have found out it can be a disappointment when you get the answer too late.
    To me a decent salesman should know the answer or give you a manual to have a look Im sure it would be in there.
    Is almost impossible to get it uprated as well without major modifications. Even the big Cruisers that have had their GVM up graded by several hundred KG dont get the towing capacity or towball weight increased and in some cases have had capacity reduced due to their published Combined gross vehicle mass limit
  10. #30
    Mar 2011
    all over the place
    Hi Shane,
    In the detailed Tiguan specification file (page 11) the towbar load limit is listed with 100 kg.
    Isn't that what the figure you said doesn't get published? The file is available on their website.
    Lupo
