Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: ACC Refused to engage - red pointer
    Jun 2017
    North Sydney, NSW
    Quote Originally Posted by sVWatt View Post
    Cap. Will actively brake going down a hill, to keep me within 1-2kmh of set speed. Golf and Tiguan act the same.
    So I would prefer ACC that I can override when I need to overtake, rather than the speed limiter leaving me hanging mid manoeuvre. Lol.
    I'd assumed the speed limiter was 'only' a chime to remind people to check their speed. And you could boot passed the limit set if you wanted or needed to.
    Has anyone actually tried it?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Oct 2017
    Ashburton, Victoria
    If you push the throttle hard enough you'll feel a "bump" and it'll accelerate over the speed limiter you've set. At least it does on my Passat!
    Sep 2012
    Quote Originally Posted by pyridinite View Post
    Yes, you need to press the kickdown switch to override the limiter.
    MY13 Golf GTI DSG (SOLD)| Candy White | 18" Detroits | Bi-Xenon Headlights | Street Guardian SG9665C
    MY18 Golf R DSG | Indium Grey | 19" Spielbergs | DAP | Sunroof | Viofo A119v2 (front) | BlueSkySea B1W (rear)
    Micro-CAN VCDS
    Jun 2017
    North Sydney, NSW
    Quote Originally Posted by Kevlarman View Post
    What’s a kickdown switch?
    Jun 2017
    North Sydney, NSW
    Makes sense. I’ll give it a try.
    Oct 2017
    Ashburton, Victoria
    Quote Originally Posted by spacemannz View Post
    Little switch at the bottom of the pedal travel that tells the car to give it everything it has, override any speed limiters and shift down a gear if possible. Press till you feel it hit the end and then press harder - that's the switch.
    Jun 2017
    North Sydney, NSW
    Never knew that. Seriously. I always thought it kicked down in response to throttle angle and velocity. It’s been a while between cars and first VW so I must’ve missed some tech. Cheers for the tip!
