Results 1 to 5 of 5
Thread: ACC disabled when revertng back from Traffic Sign detection
    Nov 2016
    canberra
    Hi,
    When I try to revert back the settings for Traffic Sign Detection (to default no detection, the ACC gets disabled.
    There is Byte 24, Bit 6 that is Traffic Sign Detection value in A5 long coding. When I change it back to not activated the system de-activates the ACC at the same time.
    Any idea what is causing my ACC to not available ?
    Jun 2018
    Bogota Colombia
    I did it with the app from obd eleven and it generated an error in the infotainment system. I had not issue with the acc I could reverse it using the app from obd.
    Sent from my SM-G9650 using Tapatalk
    Jun 2018
    Quote Originally Posted by Aus_fas View Post
    Hi,
    Hey mate,
    Did you end up finding a fix for this? I think I am having the same issue.
    Nov 2016
    canberra
    Yes, I did, as I found out there was one bit I shouldn't have touch. Will post the details by this weekend
    Sent from my HTC U11 using Tapatalk
    Nov 2016
    canberra
    Quote Originally Posted by nbolz View Post
    Hey mate,
    Okay, here are my notes for that fix.
    Now going through the detail:
    The issue turned out to be in ACC- 13 module
    13 radar:
    320047C358FF8428749C8065303085
    While I was going through the entire history last night I found out that last month when I first tried to revert the changes. I also changed bytes 1, 4, and 6 of this module. One of the bits in Byte 1 was for traffic sign and that is why ACC was interfering when I have been trying to default Byte 16 /bit 4 of A5.
    I defaulted 4 and 6 of the above module this morning but after receiving your email and checked and changed the byte 1 as well. I'm not sure why I changed these one in July. There are possible reason, I may have accidentally entered into the module instead of A5 and then looking at Emergency Assist, Traffic Sign values end up enabling them. Otherwise I see no logical reason to it.
