This is what I think they have ✅
EDIT: have a look at this video. About 10:50 into it, he goes into the assist menus and also shows the button on the stalk. Note, he does not have all 4 assist functions, but this video shows what I have on my 2018 Allspace Highline R-line.
Hope this helps clarify the “button” situation
Youtube
2018 Allspace 162TSI R Line
I think this must be a change in the 19 model
mines an ‘18 model and I think (don’t know) that the ‘18 SWB was the same as Allspace
To the OP, maybe take it into dealer. Maybe something broke
What is the build date either on the sticker or on your purchase documents
Mine is November 22nd
Here is the menu I get 1st one is start of it 2nd one is rest as you scroll down
Also as you see if you compare your pic with mine your round dials have receded to the Nav size whereas mine are still at full size but with the assist menu
Hi Hillbilly.
Those original pics you refer to are off the internet - I just googled them for reference.
Mine look like the below.
1st pic is accessing the Assist menu via the "Views" using the button on the RHS of the steering wheel (note the back arrow in the menu)
2nd pic is using the shortcut button via the LHS stalk
Mine is a July 2018 build. I don't have access to ACC and Speed Limiter through the Assist Menu (or LHS stalk).
These are only available through the buttons on the LHS of the steering wheel.
I like the look of the older AID but prefer the more customisation options in the new one
As per my photos above, I'd prefer to have speed and avg fuel consumption in the middle of the gauges, and then I would just have satnav always on display.
At present I have the above view, and digital speed in the central space.
When using sat nav, I then change the gauges to be gear/speed in the centre of the gauges
Mine is set as in the pics and stays that way Cant be fussed with av fuel etc.. just fill it when its empty and speed in r/h ring
Can have too much information that leads to worrying which leads to other probs like nail biting because car did .2 more L than it did yesterday
ROFL
