At the end of the indicator stalk there’s a button which controls whether ACC/lane assist etc is turned on or off. Not sure if cruise control is in that list, but might be worth checking to see if it’s turned off (unchecked)
Hello Everyone,
I have a 2018 Tiguan 162 Highline and today my cruise control stopped working.
I can use the buttons on the left to select a speed however when i hit "Res" or "Set" the speed does not illuminate. The vehicle is not throwing any errors at me and the "Speed Limiter" function works fine. The car is also showing that it is detecting cars and lanes around me when i drive so i do not believe it is a sensor issue. Front assist is also working perfectly.
Any ideas? Is there a way to reset the Cruise Control?
Thanks in advance![]()
There are no buttons on the ends of the stalks in my R line
Sequence is press top r button to turn ACC on get up to speed and hit set if you have to brake you then need to hit res
When you hit The ACC button (T/R) the distance in bottom right of the AID changes to the ACC sign with the speed you are doing You adjust to what you want and hit set
Lane assist is set from the Media menu
There are definitely buttons at the end of the stalks, maybe the 2019 model doesn't have it? Seems a bit weird though.
The ACC is not an option in that though.
Also, I know how to engage my ACC. I have been driving the car for the past 6 months without issue, it is just recently that it is not engaging. Hence wondering if there is a way to reset the system.
Thanks again![]()
I have 2018 R-Line Allspace and the stalk on the LHS has a button (not obvious) on the end.
This is a shortcut to Driver assist systems (Lane assist, Blindspot, etc)
When you press it, you should see something like this
The other thing to make sure is that you have the ACC on.
On the LHS of the wheel, there is a Mode button
This toggles between ACC and Speed Limiter
Make sure you have it set to ACC
And then make sure the button above is switched on to make ACC or Speed Limiter active
2018 Allspace 162TSI R Line
The button is there but you might not think it is. Press it and a menu as shown above appears on the screen. I had the same issue was not aware it was there or the quick access driver assist menu was available in such a way.
Not on mine its not There is a blank end with a fine ridge across it and nothing to push at all I can scroll through the menu in the AID using the silver ones on the right side of the wheel to get assist systems and cant change into speed limiter. The assist menu is rather different from the pics as well.
That does go against the advertised features. If you have DAP, you’re meant to have the button on the end of the indicator stalk. But I’m not surprised- it’s vw, after all. Quality control isn’t in their vocabulary.
