Results 11 to 20 of 28
Thread: ACC/Cruise Control Not Engaging
    Jan 2019
    Camden, NSW
    The latest model has all the controls for ACC on the steering wheel. Not on the stalks.
    Are you saying "speed limiter" function as you can't get out of that mode?
    Dec 2010
    Helensburgh
    The ACC controls have always been on the wheel and if the button is not on the end of the trafficator arm take it back and get a new car.
    Dec 2010
    Helensburgh
    WHat does it do that Icant with the buttons on the other side of the wheel
    Read post 6, it goes into the driver assist system menu. How do you get into that now?
    Oct 2015
    Hillbilly is right, all the adjustments can still be made, just a different sequence of events to get to them.
    Why the hell vw mess with things like this, does my head in. Stop being cheap.
    Pacific Paradise QLD
    Quote Originally Posted by Ozsko View Post
    Also answering this reply "Read post 6, it goes into the driver assist system menu. How do you get into that now? "
    None of us are always right and you are not in this case
    CAR
    TIGUAN162 RLINE with DAP and SOUND PACKAGE
    DOES NOT HAVE BUTTONS ON STALK
    You use the righthand buttons on steering wheel as follows
    Turn engine on . using the siver buttons around the OK button scroll right and in the top row of the AID you get NAV, AUDIO, TELEPHONE,CAR STATUS, DRIVING DATA, ASSIST SYSTEMS.
    When you get on Assists you press the DOWN button to the right of the siilver one and you get a menu which is like this with boxes to check the ones you want EXCEPT FOR ACC and SPEED LIMITER which you have the choice to highlight one or the other
    Menu is
    Lane assist
    Speed adjust.
    ACC
    SPEED LIMITER
    Side assist
    Rear assist
    Front assist
    Back (to top)
    If while in there you press VIEW which is below the silver ones you get car data like consumption oil temp and other stuff
    So I wont be taking my car back and suggest perhaps you should
    Perhaps you are in the wrong thread as my Passat had a button on the end of the stalk which reduced the ACC speed by 1kph increments.
    The ACC controls are in fact on the left side of the wheel around the matching silver ones and all settings can be adjusted from there.
    Attached are pic of end of both stalks in my car As you can clearly see someone forgot to put buttons on them
    Left pic is left one rightpic is right one
    Attached Thumbnails Attached Thumbnails ACC/Cruise Control Not Engaging-20190517_083955[1]-jpg   ACC/Cruise Control Not Engaging-20190517_084037[1]-jpg
    Jan 2019
    Camden, NSW
    You can also press and hold the Mode button on the left side of the wheel to access the DAP options.
    Jan 2019
    This thread is cracking me up, all over a button.
    Quote Originally Posted by Beedub View Post
    Pushing your buttons is it
    Oct 2018
    Melbourne, VIC
    I just feel bad for the OP - thread got hijacked all because I mentioned *that* button...
    Poor guy hasn't even got a solution yet!
    Quote Originally Posted by PDMJO View Post
    He probably would if he took it in to the dealer instead of wasting time waiting on an answer on here when a 5 min trip would have cleared it up.
    Who knows what people change in menus that upset something else and dont include that in the request
    He possibly unknowingly turned on the speed limiter thereby disabling the ACC. Who really knows.
