I've logged my car to look at how much timing retardation the ECU is pulling. I've then had the ECU retuned to operate safely on the fuel I'm running. In this case it's Caltex Vortex98 which in SA is definitely not the same as other 98 octane fuel on the market. Generally the manufacturers will put in a tolerance for poor quality fuel in the ECU, however like I said the ECU can only pull timing so far before you get detonation (typically only around 5 degrees).
