Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: IS 38 Turbo
  1. #21
    Aug 2021
    Quote Originally Posted by InsaneAsylum View Post
    Wouldn't fitting an is38 make your engine the same as a Golf R engine and therefore a Golf R stage 1 tune would be appropriate, or Golf R stage 2 if you're fitting a DP as well.
    There are further differences between the two engines beyond the turbos, so a Golf R tune is not a plug-and-play proposition.
  2. #22
    May 2012
    You can kiss the warranty goodbye on your engine and transmission.
    so best option is to upgrade to a Golf R?
  3. #23
    Mar 2021
    Quote Originally Posted by petemac110 View Post
    Thanks for clarifying that, I wasn't aware. I was under the impression that the Golf R was essentially a GTI with a haldex/4WD and an IS38
