Originally Posted by
tigger73
1. Generally most 17” wheels for VW/Audi will fit. They need to be 5x112 (diameter and number of bolt holes) and if you get wheels from an Audi you’ll also want a hub ring (to locate the wheel on the hub when you put it on as the Audi’s run a larger hub. VW hub is 57.1mm and Audi is 66.6mm. If you don’t use the hub rings the wheel can be bolted up off-centre and cause vibration. You can buy cheap off eBay so no reason not to get a set.
Only other thing you need to consider is offset. Tiguan offset is around 38-41mm. This is the distance away from the centre line of the rim that the wheel mounts on the hub. The bigger this number the more inwards the wheel sits. You ideally want to keep this in the 30-40 range for a Tiguan. Especially with an R-line with extended guards you want to have the wheel sitting a little more outwards if possible. This is more from a cosmetic than driving point of view, however if you do deviate too much you’ll change the track of the vehicle what can change handling/dynamics. A few mm either way is not going to be noticeable.
Generally Passat and Scirocco wheels and also first gen Tiguan will be fine, however the tyres will need to be changed for correct diameter (tyre spec are in you fuel flap).
2. eBay, gumtree, Facebook VWW classifieds. Prices will vary depending on condition of wheels and tyres and demand.
3. Factory warranty won’t cover the new wheels/tyres obviously. As long as you keep to standard factory sizes all other warranty should be unaffected.
4. Yes as long as you keep to factory standard sizes/offsets there should be no issues.
You are a walking encyclopedia tigger 73.
MY18 Tiguan R Line Black-162 Highline TSI
Drivers Assistance Package - Sunroof - Tow Bar
Ordered July 17 Arrived December 17 Delivery Jan 18
