Then I will add one last negative comment, I had a 1.6TDI diesel Passat previously while in EU, the only similarity was the Turbo, You really have to get used to it. If you accelerate slowly (gradually) it is (nice and smooth) not an issue however if you press down less than half way and expect to accelerate somewhat then you wont get it as it may not be enough to trigger the kick down. You need to give it a good press down for kick down into lower gear. Its just a matter of adjusting your driving. I hate coming out of a corner and NOT pressing the accelerator down enough for it to kick down a gear and GO GO GO. You know the feeling you get when your expecting a take off and it doesn't happen.
Your left with that forward crouch waiting for the pull.
As I said you get used to it, its a more economical way of driving I guess.
On the brighter side, Take off from the lights with a little pedal and when you hit 2nd gear you really feel the pull.
Comparing other features such as Lane assist and ACC with the Mazda a family member has, the VW does everything, But Better. VW just have too many advantages to even mention.
TEST DRIVE it before making a final decision. Too many people I know just sit in the car and look out the front window when evaluating a car. You need to be comfortable when driving the car. A mistake I ALMOST made.
If your budget is around 40K then 1.4TSI WITH
DAP wont disappoint
. (DAP is a must).
