Audi (66.6 mm) has a different hub centre size to VW (57.1mm)
So u'll likely need an adapter to make the wheels size on ur hub.
Also.....265mm wide wheels!!! That's gonna cause issues, including scrubbing.
Hi, i bought used audi alloys 20*9. Can i fit wheel size 265/35/20 to Passat B8 r spec?
TIA
yep, gonna rub, maximum rim/tyre size is noted online on a few sources for B8 is 235/40/19x8. You could possibly fit something like 255/35/19x9 if you want extra width, but you'd need to check what offset works. Further, if the R-line spec includes a lowered ride height from standard, you'll need to do a few other things.
There are a few on-line rim and tyre size tools that will assist to give you an idea of what might fit.
