Results 1 to 3 of 3
Thread: Whats your Passat Battery size and spec?
    Apr 2017
    Exclamation Whats your Passat Battery size and spec?
    Hi everyone
    Could your provide some details of your Passat battery specs?
    TDI TSI 206 please
    My 132 TSI has a 12V 69Ah 360 DIN EFB battery.
    It seems like the battery size is small and causing the start stop system refused to work some times.
    Please help
    Neal
    Pacific Paradise QLD
    Sounds about right My B7 has a Varta AGM 12V 68AH 680A EN/SAE/GS 380A DIN
    part no 000 915 105 CC
    Sounds more like you arent holding the brake pedal down hard enough to initiate the stop start
    The engine will only stop if you hold the brake fully on as apparently there is a pressure sensor in the brake line that senses enough to stop the engine, not enough and it wont stop.
    Similarly I can lift off a bit and the engine will restart but the car wont move.
    Handy to do to anticipate the lights changing
    May 2007
    140TDI Highline - (VARTA AGM) VAG Part No. 7P0 915 105 / 12V 68Ah 380A DIN 680A EN/SAE/GS
