Hey folks, I've just recently got a 2016 140TDi Highline w/ Lux pack and I'd like to do the sunroof close tweak and get traffic working..
I recently bought a VCDS cable from Total Car Diagnostics... turns out it's a 12.12 version cable/software..
It seems to work and report everything ok on my MY13.5 Touareg, but when connected to the Passat, I get .ROD file errors.
According to the TCD emails delivered after ordering it, it claims it only works with version 12-12.
I tried to download VCDS 18 off Ross-Tech site, but it won't find the interface..
Am I kinda stuffed here?
Hi mate,
I've had a look at the website for the product you bought and yep, you're pretty stuffed. They're even open that they're selling fake cables and that it's limited to only their cracked 12.12 version.
VAG-COM VCDS 2018 - OBD2 Diagnostic Cable & Software (for VAG Cars: VW, AUDI, SEAT, SKODA)
I'm totally blown away they're selling fakes. Just wow.
Edit: I've reached out to the team at Ross-Tech to let them know TCD are selling these ****ty fakes.
What's needed is:
Sunroof Comfort Closing/Opening:
1. STG 09 (electrical wiring)
2. STG Access Permission -> Function 16
3. Enter access code 31347
4. STG Adjustment -> Function 10
5. Channel (10) access control Select 2-SAD Comfort close
6. Set value to active
7. Channel (11) access control 2-SAD Comfort open
8. Set value to active
Enable Traffic Information (TMC)
Step 1. On "Select Control Module" option click "Select"
Step 2. Select "5F-information Elect"
Step 3. Select "Adaptation"
Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
Step 6. Click the "Yes" tab in the "Re-code Invalid" screen if it pops up. (mine didn't).
Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
See if you can do any of the above with your current cable first.
I can help you if it doesn't work out. I'm in the eastern suburbs. PM me. My fee is a 6 pack of nice beer for simple coding.
I tried sunroof coding but when I went in to stg09, I got an error in vcds about a missing .rod file. I was able to enter the security code but can’t access 10-adaptation as it’s greyed out.
I tried copying the newer rod files from
V18 vcds which I downloaded from rosstech, but it didn’t seem to work. 10 is always greyed out in multiple menus.
Didn’t have this issue on my other car though so much just be an age/compatibility thing..
I’m immobile for the next few weeks thanks to foot surgery so no rush I guess. A 6er is easily done
