have you got pro?
if you have go into the modules and look around (as long as you don’t press and hold the green tick nothing will be changed) find the adaptions and look through and see how they work, then find the long codings and see how that works, maybe go on the obdeleven boards and read through the how to’s to get more info, then find a tweak you want, go through every instruction in it, see if you can find everything that needs to be changed, if you can then go back and change them with saving by the green tick, check rweak works
dv52 has some great pictures and info on here
This link by DV52 will be your best mate.
OBDEleven - The new kid on the block!
Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
Previous - Passat 206TSI MY17 - Night Blue
Hello guys,
Just read all the tweaks for MY17 Passat B8. (Europe ver.)
I wanted to try setting in 09 Central Electronics / (1) so that I can lock my car with key while engine is running, but it seems like Channel is not available.
My car does not have Keyless Entry, only Keyless go. Anyone can help me how to set-up this feature?
Also, could not manage to set-up Lane Assist (or the ALG) / TJA, anybode care to share the link or the coding?
Thanks!
Autoscan: https://pastebin.com/embed_js/SPjEJTBz
TJA is vcp coding only or vw if they want to but chargeable either way
interesting you have keyless but not kessy, do you have the kessy door handles?
also with the door locking thing are you looking for access control? As the newer modules have it under different parent names now and it’s now under ZV allgemein, as zv is the intitals of zentralverriegelung which is German for central locking and ellgemein is general
No, I do not have keyless doorhandles (I saw at one of my colleague's MY17 Superb how they should look).
I did not equip my car with Keyless Entry (kessy) because I hate the system, I always push the key button to unlock/lock. For me this system is like having to manually turn the key into the fob to lock the car. I only start the engine without the key.
About TJA - I will ask VW Dealership if they want to activate it.
In the meantime, I will try again to code with vcds:
- Lane Assist - Activate Lane Assist - VCDSSchweiz
- Sign Assist (is this the same thing with the Dynamic Road sign feature?) - Activate Sign Assist - VCDSSchweiz
LE:
Yes, as I now remember, I have tried (1) Access control - something with "15" in its name. So I should search for "ZV"
With kessy you can lock/unlock the car with the fob, you can also program it so the door handles don’t work ��
but it you must have ALG and ACC for TJA to be enabled
Yeah, what I meant was I wouldn't even use keyless entry, I only use the fob anyway.
TJA - I know I need ACC + DSG + ALG. I lack only ALG which I should be able to activate (even though I didn't find the tutorial yet).
I can activate these because I do have the A5 camera as you may see in my autoscan.
Have you got lane assist?
