Results 1 to 10 of 236
Thread: VCDS Tweaks
    Nov 2016
    Auckland
    Trying to enable traffic and I don't quite have the same details as as the Traffic data above.
    On my radio settings I only have 'enable radio data', not the TP option or any mention of RDS? Is there some coding I need to do first to make these show? Radio stations do show scrolling banners and songs etc. But no TP ref on any of the stations and Traffic menu option just has the line through the TP at the top with no info so...?
    We have done the mentioned steps below in VDCS to try and enable everything but no options as above in the Radio set up menu afterwards?
    Enable Traffic Information (TMC)
    Step 1. On "Select Control Module" option click "Select"
    Step 2. Select "5F-information Elect"
    Step 3. Select "Adaptation"
    Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
    Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
    Step 6. Click the "Yes" tab in the "Re-code Invalid" screen if it pops up. (mine didn't).
    Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
    Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
    Please note the following after the tweak has been completed:
    1. For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
    Using VDCS have enabled; light assist, Rear LEDs, reduced auto hold pressure, and tried rain closing so those all seemed to work fine but the traffic one is eluding us currently?
    DV52 wondering if you can help please? I have a March 16 206 Passat, we got them earlier in NZ than Oz but same spec.
    Now: MY16 VW Passat 206TSI R-Line 4motion
    Before: MY14 Skoda Octavia VRS TDI Manual, MY10 Skoda Scout TDI manual
