^^^^^^^^^^^ hmm............ lots of "cross-fertilization" of the tweak instructions that are described in detail in the mk7 section of this forum and some of those that have been (largely) copied here! Not surprising given that both the later versions of the Passat and the Golf mk7 share the same build platform (MBQ), and I'm not complaining- I view the replication as the sincerest form of flattery (albeit attribution is a nice thing to have IMO)!!
But, just to save time and to make the process more efficient - it's much easier to simply find the instructions for your tweaks HERE - I suspect many of these will be the same!
Finally, for those that have opted for an OBD11 dongle (instead of VCDS), you can find a range of (mostly) suitable tweak instructions for your Passat HERE - again, no need to copy-and-paste the dialogue here!
Yes, for now, most of the tweaks cross over, but it's probably best to keep a version in here as there are quite a number of features on the Passat that do not feature in other MQB platform cars. If it's stuck in a "Golf" sub-forum then the less technically inclined may never find it.
