Page 8 of 24 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 236
Thread: VCDS Tweaks
  1. #71
    Jul 2017
    Auckland, NZ
    I get an error when trying to access module A5. Im using the correct code...but gives an error every time.
  2. #72
    Feb 2013
    Perth, WA
    Check to make sure it's not thrown any codes. Sometimes you need to clear codes before trying to access it.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
  3. #73
    Quote Originally Posted by Hugo_nz View Post
    Hugo: what access code are you using?
    I assume that you are aware that control modules get cranky if you input an incorrect access code - they won't respond to any other attempt to enter a new security code for a period of time (5-20 minutes) -measured with the ignition turrned on.
  4. #74
    Jul 2017
    Auckland, NZ
    Got it working thanks. Cleared the app data and it accepted the 20103 code
    Have you done any coding on the ACC module?
  5. #75
    Jul 2017
    Auckland, NZ
    Got the fancy-pants sport theme on the AID
    Dash Board (17) -> Adaption -> Tube_version -> Variant 4 (Default for me was Variant_2)
  6. #76
    Feb 2013
    Perth, WA
    Dammit. I can't see that option. Did you enter a security code or something?
    Are you using VCDS or another tool?
  7. #77
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by Wynnston View Post
    I'm using OBDEleven.
  8. #78
    Feb 2013
    Perth, WA
    Anyone in Perth with OBDEleven want a few beers ?
  9. #79
    congrats, shame its only on the obd11,m i cant find it on the old rt cable.
    they look way better then the stock ones.
  10. #80
    Jun 2017
    Perth, WA
    So should I be buying the OBDEleven or VCDS!?
    His: 2018 Golf 7.5 R Wolfsburg Edition Hatch
    Hers: 2017 Passat B8 206 R-Line Sportswagon
