Originally Posted by
chopsticle
Not sure if this has happened to anyone else..
The Passat was @ Werribee VW getting a potential oil leak looked at (seems to be false alarm, phew!).
While there, they claimed there was some directive from VW to update a door controller or something along those lines.
I didn't think anything of it, but since they've done this, the comfort open/close no longer works..
I've checked VCDS 17.8 and it reckons it's all enabled, but nup.. I've tried both remotes and got nada for open/close.
Anyone come across this or have any ideas besides taking it back and complaining? I had to tweak to turn that stuff on in the first place.
It sounds lik you just need to run calibration, it can happen after a controller is flashed and reset or the battery is pulled. For each window, put it all the way down, then pull and hold the switch until the window comes to the top, keep it there for a few extra seconds once it's up. Then repeat the same process once more. Once done it should behave itself. If not, take it back to the dealer.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
