achk: Hi I'm in the north-eastern suburbs - if you haven't had a response yet and you are interested - PM me (no beer necessary - I just need your undying gratitude -:cool:
Printable View
Yes, for now, most of the tweaks cross over, but it's probably best to keep a version in here as there are quite a number of features on the Passat that do not feature in other MQB platform cars. If it's stuck in a "Golf" sub-forum then the less technically inclined may never find it.
Has anyone managed to find coding to turn off the beeping sound when the wagon boot/tailgate is opened using the key fob or the boot release button in the drivers door? I was pointed to coding for a Skoda Octavia using OBDeleven on youtube but the adaptation on Skoda doesn't exists on the Passat.
Thanks.
Does anyone know how to remove the nag screen?
This is how I did it using OBDeleven:
1. Select control unit 5f
2. Select Long Coding
3. Change Byte_23_initial_disclaimer to "Off"
4. Save setting
Had a bit of a der moment. This thread is titled VCDS tweaks. Does the OP or anyone have an issue with OBDeleven instructions being added. Happy to start another thread.
VCDS screen
http://www.vwwatercooled.com.au/foru...4mK1dpng-1.jpg
OBD11 screen (as per zfl001
http://www.vwwatercooled.com.au/foru...tzqhIpng-3.jpg
sorry i dont have alarm fitted
Trying to enable traffic and I don't quite have the same details as as the Traffic data above.
On my radio settings I only have 'enable radio data', not the TP option or any mention of RDS? Is there some coding I need to do first to make these show? Radio stations do show scrolling banners and songs etc. But no TP ref on any of the stations and Traffic menu option just has the line through the TP at the top with no info so...?
We have done the mentioned steps below in VDCS to try and enable everything but no options as above in the Radio set up menu afterwards?
Enable Traffic Information (TMC)
Step 1. On "Select Control Module" option click "Select"
Step 2. Select "5F-information Elect"
Step 3. Select "Adaptation"
Step 4. Using pull-down menu, select "Fee Based Traffic Information (TMC)" channel (it's about 20% down the channel list)
Step 5. Enter "1024" into "New Value" box and click "Do It!" tab.
Step 6. Click the "Yes" tab in the "Re-code Invalid" screen if it pops up. (mine didn't).
Step 7. When the screen in Step 5 returns, click "Add to log" to record a copy of the change report.
Step 8. Click "Go Back" (in Step 5 screen) and exit the VCDS software
Please note the following after the tweak has been completed:
1. For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio
Using VDCS have enabled; light assist, Rear LEDs, reduced auto hold pressure, and tried rain closing so those all seemed to work fine but the traffic one is eluding us currently?
DV52 wondering if you can help please? I have a March 16 206 Passat, we got them earlier in NZ than Oz but same spec.
snala: So - as I understand for the SUNA service (here in Australia, at east), the actual TMC data is transmitted over the commercial FM radio - it uses a harmonic of the stereo sub-frequency in the RDS signal (I think). The MIB unit (the module that lives in the glove box on a mk7 Golf) combines this information with the GPS data to locate the TMC data on the map that you see on the screen.
RDS also carries other data on the FM band - like the name of the song being played, or the weather information that is sometimes shown on some FM stations. So, if you have this information displayed, you probably already have a base level of this function activated.
Now we get to the difficult part - From my work with the MIB units on a mk7 Golf, I have found that the RDS function is enabled via Byte 13, Bit 3 on the 5F control module as per the VCDS screen shot below:
http://www.vwwatercooled.com.au/foru...ooCDCpng-3.jpg
BUT - as you can see from the screen shot - there are lots of Bits on Byte 13 not shown with VCDS.
Here is a screen shot from my OBDeleven dongle for Byte 13 showing the Bit which refers to the same " RDS plus" facility as well as a basic RDS function and another reference to RDS on Byte 14 (boxed in yellow) - the reference to RDS plus on the second screen is a duplicate of that on the first screen
http://www.vwwatercooled.com.au/foru...hRcVpng1-3.jpg
http://www.vwwatercooled.com.au/foru...iFDKMpng-1.jpg
Unfortunately, there isn't an easy way of determining which Bits the OBD11 entries relate-to. So alas I can't make any definitive suggestions for your car. But you could try experimenting!
