Page 13 of 21 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 236
Thread: VCDS Tweaks
Wynnston VCDS Tweaks 25-03-2017, 09:56 PM
kamold Note that some of the MQB... 26-03-2017, 08:38 AM
AJ240 Enable Traffic Information... 26-03-2017, 01:29 PM
mikeb27rs Hi, I have done this on my... 02-08-2017, 08:25 AM
AJ240 If you want to be able to... 26-03-2017, 01:31 PM
AJ240 This will turn on the outer... 26-03-2017, 01:25 PM
Wynnston Thanks for the alarm chirp on... 27-03-2017, 10:53 PM
zfl001 Great thread. Hopefully will... 28-03-2017, 08:11 AM
CaseySP Would be interested if there... 28-03-2017, 09:45 PM
achk Anyone in Melbourne happy to... 06-04-2017, 05:45 PM
DV52 achk: Hi I'm in the... 07-04-2017, 02:56 PM
ylzhao sorry i dont have alarm fitted 01-05-2017, 12:12 PM
DV52 ^^^^^^^^^^^ hmm............... 07-04-2017, 02:49 PM
Wynnston Yes, for now, most of the... 09-04-2017, 12:26 AM
zfl001 Has anyone managed to find... 24-04-2017, 09:58 PM
zfl001 Hi, So poked around some... 29-04-2017, 12:19 PM
keepleft Does anyone know how to... 29-04-2017, 06:03 PM
zfl001 This is how I did it using... 29-04-2017, 07:13 PM
DV52 VCDS screen... 30-04-2017, 06:35 PM
snala Trying to enable traffic and... 09-05-2017, 06:10 AM
DV52 snala: So - as I understand ... 09-05-2017, 02:42 PM
snala Thanks Don. Will keep... 10-05-2017, 06:24 AM
Wynnston Odd. I have no Long Coding... 30-06-2017, 05:05 PM
snala Yes it worked for us. Main... 03-07-2017, 11:38 AM
Odamuz Hey lads... Long time lurker,... 09-05-2017, 08:29 PM
kieranr Quick question, apologies if... 14-05-2017, 06:18 PM
kamold Yes Sent from my HTC 10... 14-05-2017, 06:32 PM
kieranr Excellent. Thank you!! 14-05-2017, 08:27 PM
bunglebp Just have to say enabled RDS... 16-06-2017, 07:35 AM
Razman10000 Has anyone had any luck... 20-06-2017, 11:30 AM
ope126 So was able to get some... 23-06-2017, 09:16 PM
snala We used Ross tech on Laptop... 29-06-2017, 06:27 AM
Wynnston Is the throttle pedal... 29-06-2017, 09:13 AM
ope126 Yes, and no issues to... 29-06-2017, 10:19 AM
Wynnston Odd. Mine is just on already.... 28-06-2017, 11:50 PM
Razman10000 Sorry Wynnston, I should... 30-06-2017, 03:11 PM
Wynnston Yes. It's called Adaptive... 30-06-2017, 05:03 PM
kamold That means vcds doesn't have... 30-06-2017, 06:44 PM
Wynnston Ah, yep. That will be it.... 30-06-2017, 06:48 PM
Wynnston Looks like I lucked out, I... 30-06-2017, 08:23 PM
kamold If it's too new you should... 30-06-2017, 09:22 PM
Wynnston It's really odd, I have the... 30-06-2017, 09:41 PM
kamold Haven't seen that. Email... 30-06-2017, 10:21 PM
DV52 kamold: forgive my... 01-07-2017, 10:04 AM
kamold Thanks Don, That would... 01-07-2017, 10:10 AM
DV52 ^^^Wow - and I assume that... 01-07-2017, 10:18 AM
kamold Got CAN modules up the wazoo-... 01-07-2017, 10:48 AM
mikeb27rs Hi, I have a White MY17 2016... 18-07-2017, 09:13 PM
mikeb27rs Hi, I have a White MY17 2016... 18-07-2017, 09:14 PM
DV52 Mike: hi As to your... 19-07-2017, 10:37 AM
mikeb27rs Hi Don That worked great,... 02-08-2017, 08:42 AM
Wynnston I seemed to only get this... 02-08-2017, 06:29 PM
DV52 Mike: well done with the TMC... 03-08-2017, 11:25 AM
Wynnston If it helps this is where I... 03-08-2017, 03:13 PM
Diegothecat Ive have been able to make... 31-07-2017, 02:43 AM
ope126 Well done with the above... 31-07-2017, 07:19 AM
DV52 Dieago: Hi - sounds like you... 31-07-2017, 08:35 AM
Diegothecat Yea Don I get what your... 31-07-2017, 09:02 AM
Wynnston Do you have pictures of the... 01-08-2017, 11:22 AM
Diegothecat Yea thats one of the options... 01-08-2017, 08:02 PM
Wynnston Ok, you have me interested.... 02-08-2017, 10:01 PM
vwcaddy123 How do you change the dials... 10-10-2017, 03:39 AM
Diegothecat Hey bud look me up and Ill... 28-10-2017, 10:19 AM
Diegothecat Here is a little vid of the... 01-08-2017, 10:41 PM
DV52 Diego: Alas that's the... 03-08-2017, 11:09 AM
kamold They are free because you are... 03-08-2017, 07:52 PM
bunglebp Heya all I have a 2017 206TSI... 08-08-2017, 01:14 PM
Wynnston It's static white. The LED's... 10-08-2017, 10:32 PM
Skoda729 Is there anyway of getting... 16-08-2017, 09:45 AM
Hugo_nz I get an error when trying to... 16-08-2017, 07:53 PM
DV52 Hugo: what access code are... 18-08-2017, 05:48 PM
Hugo_nz Got it working thanks.... 18-08-2017, 05:50 PM
Wynnston Check to make sure it's not... 17-08-2017, 10:14 PM
Hugo_nz Got the fancy-pants sport... 20-08-2017, 08:13 PM
Wynnston Dammit. I can't see that... 21-08-2017, 09:29 PM
Hugo_nz I'm using OBDEleven. ... 22-08-2017, 04:40 PM
Wynnston Anyone in Perth with... 22-08-2017, 05:02 PM
Diegothecat congrats, shame its only on... 22-08-2017, 05:40 PM
Jap gti clocks 😉 30-09-2017, 07:47 AM
Jimi Is it possible then to change... 22-08-2017, 11:31 PM
Diegothecat Obd11 but it's nice to have... 23-08-2017, 12:02 AM
Diegothecat It's about time apple missed... 23-08-2017, 02:20 PM
mythik So. Spent a bit of time last... 27-09-2017, 08:58 AM
ope126 Mythik, that is a great write... 27-09-2017, 12:35 PM
mythik Please give this a go and let... 28-09-2017, 02:50 PM
ope126 Thanks mythik, I got it to... 12-10-2017, 11:40 AM
mythik Yet again, spent a bit of... 13-10-2017, 09:08 AM
DV52 mythik: It might be... 15-12-2017, 08:58 AM
DR074 works for me 30-09-2017, 09:13 AM
D4rk4n63l could anyone share the... 28-10-2017, 07:30 AM
pyridinite Is there anyone in the... 01-11-2017, 01:50 AM
Jap Oh, to get the dots on the... 14-12-2017, 08:04 PM
Dark975 Hi. If this was for me, I am... 14-12-2017, 10:32 PM
Jap You’ll have to change the... 15-12-2017, 03:15 AM
Dark975 That's the problem. With... 15-12-2017, 09:54 AM
Wynnston Tube Version shows in the... 16-12-2017, 09:34 AM
Dark975 Yep, I installed VCDS 18.1.0... 27-01-2018, 08:00 AM
Jap As I’ve said dude, I’ve not... 15-12-2017, 09:47 PM
DV52 ^^hmm............ VCP can... 15-12-2017, 09:51 PM
Jap Would it be in German?... 15-12-2017, 11:03 PM
Dark975 Let me check this tonight on... 16-12-2017, 01:19 AM
Dark975 nope about Röhrenversion, I... 17-12-2017, 03:47 AM
Blackpaladin67 Hi Peps New Arteon owner... 21-12-2017, 12:48 PM
Wynnston So I wanted to enable the RGB... 24-12-2017, 03:00 PM
Jap dont suppose you could send... 25-12-2017, 05:16 AM
DR074 did you end up getting what... 31-12-2017, 07:20 AM
Jap no I didn’t, I was after his... 31-12-2017, 06:21 PM
Diegothecat Hey bud did you have any luck... 04-11-2018, 02:28 AM
DR074 Hi Wynnston Cold Boot MIB... 24-12-2017, 06:01 PM
Wynnston Awesome!!! That did the... 24-12-2017, 06:30 PM
Blackpaladin67 Once my OBD11 arrives next... 30-12-2017, 09:38 PM
vwcaddy123 Yes, of course. Will attend... 31-12-2017, 03:23 AM
Blackpaladin67 Thank you Sent from my... 31-12-2017, 09:21 AM
point I'm very interested in this... 31-12-2017, 09:18 AM
Wynnston Does the sign recognition... 01-01-2018, 12:35 PM
Blackpaladin67 I really hope not. DTSR is... 01-01-2018, 12:49 PM
Blackpaladin67 Hoping also it compares the... 01-01-2018, 01:22 PM
Jap Found this in the acc module... 31-12-2017, 04:37 AM
Blackpaladin67 Yup that one of the features... 31-12-2017, 06:42 AM
Jap Might have to try it tomorrow... 31-12-2017, 06:48 AM
DR074 Just had a look in MY17... 31-12-2017, 07:13 AM
Jap yeah, I enabled the box but... 01-01-2018, 02:23 AM
Blackpaladin67 Here is VWs take on what... 31-12-2017, 09:23 AM
Blackpaladin67 A hint may lay in a statement... 31-12-2017, 09:31 AM
Jap Just seen this ... 01-01-2018, 03:13 AM
DR074 Yeah, couldn't find that one 01-01-2018, 08:47 AM
Blackpaladin67 My guess is it has to have... 01-01-2018, 08:55 AM
Jap Different modules? Control... 01-01-2018, 06:52 PM
DR074 Yeah, a bit different. ... 02-01-2018, 06:12 AM
Blackpaladin67 Hi All Did my first obd11... 03-01-2018, 12:16 PM
Jap have you got pro? if you... 03-01-2018, 06:59 PM
Blackpaladin67 Super thanks mate Sent... 03-01-2018, 07:40 PM
DR074 This link by DV52 will be... 04-01-2018, 06:23 AM
Blackpaladin67 Thanks heap Dr074 Sent... 04-01-2018, 10:43 AM
vvvre Hello guys, Just read all... 09-01-2018, 06:48 PM
Jap TJA is vcp coding only or vw... 09-01-2018, 08:51 PM
vvvre No, I do not have keyless... 09-01-2018, 09:09 PM
Jap With kessy you can... 09-01-2018, 09:23 PM
vvvre Yeah, what I meant was I... 09-01-2018, 09:43 PM
Jap Have you got lane assist? 09-01-2018, 09:56 PM
vvvre No, I don't have lane assist,... 09-01-2018, 09:58 PM
Jap No lane assist warns you if... 09-01-2018, 10:07 PM
vvvre Thanks, I get it now. Do... 09-01-2018, 10:38 PM
Jap I already have lane assist,... 09-01-2018, 10:54 PM
Blackpaladin67 Hi Jap The one in the lead... 12-01-2018, 07:10 PM
Jap what do you mean fella? 13-01-2018, 01:06 AM
Blackpaladin67 On this one the dots go way... 13-01-2018, 10:01 AM
kamold Don't those lines designate... 13-01-2018, 11:07 AM
Wynnston For some reason, my car had... 13-01-2018, 08:52 AM
Jap My golf, on different screens... 13-01-2018, 10:13 AM
Blackpaladin67 Ill check all this screens... 13-01-2018, 11:01 AM
chopsticle Hey folks, I've just recently... 17-02-2018, 10:51 AM
mythik Hi mate, I've had a look... 17-02-2018, 03:02 PM
chopsticle Hmm ok, thought it might be... 18-02-2018, 09:09 AM
mythik What's needed is: Sunroof... 18-02-2018, 12:41 PM
Dark975 hi. I got an alarm horn... 27-02-2018, 12:02 AM
kamold These BCMs do not have any... 27-02-2018, 03:24 PM
Dark975 Thanks kamold. I checked the... 27-02-2018, 07:15 PM
FarQ Hi there, had not much idea... 12-03-2018, 09:14 AM
tigger73 VCDS Tweaks 12-03-2018, 10:43 AM
Rocket36 Good luck getting noob... 12-03-2018, 10:07 AM
Jondalar Thanks everyone! 23-04-2018, 10:58 AM
Luca Hello, some kind user can... 05-05-2018, 05:20 AM
Jap Tube version 4 or 5 under... 05-05-2018, 05:28 AM
Luca Thanks to Jap for the kind... 05-05-2018, 05:15 PM
Rooboy It only changes the dials -... 05-05-2018, 05:39 PM
Jap All should stay the same,... 05-05-2018, 11:08 PM
Luca Modified AID from variant_3... 06-05-2018, 05:15 AM
ccbloke Hello, I'll be taking... 09-05-2018, 12:58 PM
Rocket36 +1 for tweak assistance in... 09-05-2018, 02:46 PM
FinanceGuy Hi All, Anyone in Melb... 09-05-2018, 03:37 PM
FarQ in melb and have OBD11. I'm... 10-05-2018, 09:26 AM
Rich86 Hi guys, I’ve got a mk7.5... 27-05-2018, 03:43 PM
lenny 206 rline question. Have... 14-07-2018, 05:21 PM
Jondalar You can adjust between three... 16-07-2018, 12:04 PM
Jondalar OK, strange, even my wife's... 18-07-2018, 11:05 AM
DR074 34423Confirmed 19-07-2018, 04:10 PM
lenny ok thanks, do your lights... 19-07-2018, 04:22 PM
DR074 I had it set to medium, just... 19-07-2018, 04:28 PM
Jondalar http://www.vwwatercooled.com.a... 21-07-2018, 07:20 AM
lenny i have it now coming up and... 21-07-2018, 10:45 AM
DR074 only way I know is to do the... 09-08-2018, 05:24 PM
chopsticle Not sure if this has happened... 23-09-2018, 09:22 PM
Wynnston It sounds lik you just need... 23-09-2018, 09:50 PM
Passerati Anyone in Brisbane (redlands)... 13-10-2018, 08:26 PM
Dark975 Hi. I want to disable the DRL... 13-11-2018, 03:32 AM
Goublin Hi Guys, I followed the... 10-12-2018, 09:02 AM
DR074 Door Lights are just White... 10-12-2018, 03:48 PM
Goublin looks like it, i know someone... 11-12-2018, 11:46 AM
5paul0 My MY18 has only white light... 11-12-2018, 09:12 PM
Goublin i'm sure i read on another... 12-12-2018, 09:25 AM
5paul0 I think what happened VW... 12-12-2018, 09:34 AM
lenny Having a problem with driver... 14-12-2018, 11:01 AM
kamold If it's throwing an error it... 15-01-2019, 01:32 PM
Jondalar So today I tried to activate... 15-01-2019, 07:59 AM
murmeltier Hi guys Tried to activate... 18-01-2019, 09:20 PM
    Dec 2017
    QLD Australia
    Quote Originally Posted by Wynnston View Post
    Does the sign recognition work in your model, or is it completely turned off? If it isn't enabled for the Arteon then you might have the same problem as the Passat owners have; i'm told the GPS data isn't the right type for Australia so it will throw a fault about 1 minute after the car starts, it relates to the lack of proper speed limit data from the GPS maps.
    It does work (aside from the warning), but it's a little sketchy as most of Australia isn't road signed to any reasonable standard like other markets. This means you can pickup poorly positioned signs on adjacent roads/freeway offramps. Your car could start braking in the middle of the freeway because you're doing 100km/h and the offramp (which you're not on) has a 60 sign visible from the freeway.
    W
    I really hope not. DTSR is not turned on but is in some really almost third world countries. So hoping it can work. I have read sime post in which by not turning on fusion between gps and tsr it works apparently ok?
    Sent from my SM-G935F using Tapatalk
    Dec 2017
    QLD Australia
    Quote Originally Posted by Blackpaladin67 View Post
    Hoping also it compares the gps map speed knows there is an offramp and things like that.
    Aug 2017
    Uk
    Found this in the acc module in my golf, dunno if it’s what’s needed
    Predictive_speed_limt_control
    Dec 2017
    QLD Australia
    Quote Originally Posted by Jap View Post
    Aug 2017
    Uk
    Might have to try it tomorrow then, see what it enables (if anything), be nice to have a speed limit ACC
    Sep 2017
    Just had a look in MY17 Passat. I didn't see Predictive_limit_speed_control, but did have Speed_Limit_Assistant in long coding in Module 13 (ACC).
    I checked in the Driver Assistant Settings in the "Car" Menu. I now have a tick box for "Top speed of Dynamic Road Sign Display" (it may have already been in there from previous tweaks, can't be sure). Not sure if this is the same as above posts, but thought I'd try it out. It hasn't worked so far, may need some other adjustments to work.
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Aug 2017
    Uk
    Quote Originally Posted by DR074 View Post
    yeah, I enabled the box but when I tried to enable the one in adaptions I just got function not available and it didn’t slow for a different speed limit also
    Dec 2017
    QLD Australia
    Here is VWs take on what should happen
    2017 VW Arteon Safety Features Showcase - YouTube
    Dec 2017
    QLD Australia
    A hint may lay in a statement by VW that the Arteon is the first VW with AEB from 5km to 230km or something like that. So i don't know if its carrying different hardware?
    Aug 2017
    Uk
    Just seen this
    tempolimitassistent_carmenu
    which means speed limit assistant car menu
    dodnt seem to do anything tho
