Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Tyre Setup
    Mar 2016
    Melbourne, Vic
    As others have suggested, been running 245/40R19 Michelin Pilot Sport 5's on my stock 206tsi wheels with no issues for over 12 months now. Went with a 245/40 as they're a very common size compared to the stock 235/40 and much cheaper to purchase. They're wider and the sidewall slightly taller than the stock 235/40's, but they're more comfy, don't rub at all and there's barely any changes to the speedo. No brainer imo.
    Tyre Setup-efufjdi-jpg Tyre Setup-xs6rnhv-jpg
    MY18 Passat 206tsi R-Line | Harvard Blue | Wagon
    Feb 2022
    Auckland, New Zealand
    Awesome, thanks for that green_comet. I held off the 245/35/19 RE003s as I found a much better deal for Pilot Sport 5's in 245/40/19. I'm keen to see how they perform!
    Appreciate everybodys input!
    2018 B8 Black 206TSi Estate - Thule Roof Racks - Tow bar - Dechrome - REVO Stg1 ECU/TCU - R600 Intake - CTS turbo muffler delete - CTS inlet pipe - CTS 200 cell catted downpipe w/ OEM resonator delete
    2009 B6 Black 2.0TSi Estate
    Follow my instagram for the build @rogs_passatb8 (if... you wanna...)
    Feb 2022
    Got the PS5s fitted at 245/40/19 - they're simply amazing.
    What tyre pressures is everyone using? I think for a wagon 36-38 psi is recommended
    Feb 2014
    I run ~41 PSI (280 kPa) in my PS4s tires which is toward the upper end of what the sticker tells me.
    Though.. I do lose a little traction from time to time, so slightly lower may be a better idea.
    Jan 2021
    Jest replaced my tyres to 245/40 R19s (with Hankook Ventus S1 evo3), had a good deal with $1040 AUD for all 4 tyres. Originally had 235/40 R19s (with Pilot Sport 4S) to suit the Verona Wheels.
    Things I've noticed so far:
    - Side walls seems to be softer / more of. Absorbs the initial steering input a little.
    - Noticing that the car is moving / rotating on the rubber due to increased side wall height (i think) before it settles into the corner / turn. Something I will get used to over time.
    - Road imperfections are less noticeable (cracks on the road, gravel on road etc) will be good for long drives.
    - Road noise seems to be the same
    What is everyone else experience so far?
    Also, what Tyre pressure is everyone running?
    I ended up bumping mine up to 42 PSI Front and 42 PSI Rear to stop the rubber wobble when you come to a stop and the initial rotation on the rubber before the car settles into the turn. This has improved the experience a little so far. I understand these are on the upper limits for the fronts especially when running OEM fitment. Keen to know what other's experiences are.
