Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Traffic Sign Camera?
    Hi all,
    Sorry i have another question - I have a 2017 Passat 206 TSI with adaptive cruise & Lane assist & Park assist but i want to know whether I have the camera to enable traffic sign recognition and traffic jam assist, how can i tell if can do that?
    2017 - VW Passat 206 TSI - R Line Wagon in white
    Aug 2011
    Melbourne, Victoria
    There's a thread about it here: Traffic Jam Assist activation service - Sydney
    Feb 2013
    Perth, WA
    You can get it but
    - Australian road signage is crap, don't expect it to work that well
    - Australian Nav data does not have enough data to feed the "Road Sign Fusion" so you'll get a bing and a warning about 1 minute after you start the car, telling you that road sign recognition has bombed out (it hasn't, it just isn't happy that the fusion data isnt there).
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Feb 2015
    I was able to get this working, but I agree it is no good, as the speed limits included in the maps in Melbourne are okay. They even change to 40 in school zones for the correct times in some places, but using road sign detection you loose these.
    I really just want the speed on the dash, the road sign detection does this, but ignores the ones from the maps.
    Is there anyway to get the speed limit from maps onto the dash?
    Passat Wolfsburg 2017
    Apr 2018
    Quote Originally Posted by Skoda729 View Post
    I've been trying all day to get road sign detection sorted but still have an error, could you please post the steps or a link to instructions. I'm using OBDeleven and instructions for the Tig's. cheers
    Passat Alltrack Wolfsburg Edition My18
    Feb 2015
    I do get the error message on startup.
    I used this post Link
    Apr 2018
    Thanks thats the way I did it except for this ... 6.Select Coding, and then select Byte 24, activate Bit 6 I don't get the select Byte from the long coding menu.
    Apr 2018
    Copied from Hoola - http://www.vwwatercooled.com.au/forums/f238/guide-enable-eu-specific-features-au-spec-tiguans-117741-post1226308.html#post1226308
    Summary of OBDEleven steps as follows. I compiled it from changes made by peanut, NZ_GolfR, and others on this forum so none of this is original. I tested most of these functions while out driving yesterday and today. Note I have a 132TSi with DAP and Luxury Pack, not a fully spec 162TSi with R-Line so I am missing Discovery Pro, LED lights, progressive steering and the fancy suspension settings. Your mileage may vary depending on what is fitted.
    TMC Traffic
    1. Go into Module 5F - Information Control Unit
    2. Select Adaptations, select "Fee-based traffic information (TMC)
    3. Set value from 65535 to 1024
    4. Make sure you enable traffic information in the radio, and set RDS region to automatic.
    5. Wait for about half an hour and it will receive all the traffic messages. You can confirm that TMC is working looking at the information display where it will display the TMC logo.
    Enable/Disable Daytime Running Lights in Discovery Head Unit
    1. Go ​into Module 09 Central Electronics
    2. Select Adaptations, then Aussenlicht Front
    3. SelectTagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
    4. Set value to Active. The default is "not active"
    5. Click on accept, and enter 31347 as the security code.
    6. From the Discovery head unit, select Car, then Setup
    7. Select Light, and you should see Daytime Running Light as an option
    Note, with this change, you turn on the DRL from the Discovery Media, not from the light switch. The light switch can be set to 0 and the DRL will still be controlled from the head unit.
    Adaptive Lane Guidance
    1. Go into Module A5 Front Sensors Driver Assistance System
    2. Select Coding, and change Point of Intervention to Early (Setting Via Menu)
    3. Click on "Accept", and use 20103 as the security access code.
    4. This enables Adaptive Lane Guidance as a menu option under Driver Assistance - Lane Assist.
    I have tested the difference between lane assist and ALG. LA bounces between the lane markings whereas ALG will more or less keep it in the centre. If you start drifting it will nudge it back. This works only above 65 kph. The AID will show when it is working. It works quite well with ACC.
    Automatic Window Closing in Rain
    1. Go into Module 09 Central Electronics
    2. Go into Security, use 3134 as the security code.
    3. Select Adaptations, and then ZV Komfort
    4. Select Regenschliessen_ain_aus, toggle to Active. The default is "not active"
    5. Then select Regenschliessen_art, toggle to Active. The default is "not active"
    6. Finally select Menusteuerung Regenschliessen, toggle to Active. The default is "not active"
    7. This enables Automatic closing in rain as a menu option under Window Operation
    I have yet to really try if this works or if it is just the menu as I have not been driving in the rain with the windows opened.
    Enable Refuel Quantity as Driving Data Option in AID
    1. Go into Module 17 Instruments
    2. Coding, select Byte 10 and activate Bit 4.
    3. The default is 5 litres. Pretty sure this can be changed via coding but I did not bother.
    Enable Fan Speed Indication for Airconditioning when in AUTO mode
    1. Go into Module 8 Auto HVAC
    2. Coding, select Byte 11 and activate Bit 6.
    3. This turns the lights on to indicate fan speed
    Enable Dynamic Road Sign Display
    1. Go into Module 5F Information Electronics
    2. Select Adaptations, then Vehicle_Functions_List_BAP_Gen2
    3. Select menu_display_road_sign_identification_0x21, and set to Enabled
    4. Select Adaptions, Vehicle_Function_Adaptations_Gen2-menu
    5. Select menu_display_road_sign_identification, set to Enabled
    6. Select Coding, and then select Byte 24, activate Bit 6
    7. Go into Module A5 - Front Sensor Driver Assistance
    8. Select Coding, and then select Byte 16, activate Bit 4
    9. Go into Module 17 Instruments
    10. Select Coding, then Byte 5, active bit 2
    11. Go back into Module A5 - Front Sensor Driver Assistance
    12. Select Adaptations, then Road sign detection fusion mode, and change to Road Sign Detection. The original is Road Sign Fusion
    13. Reboot the infotainment unit
    The warning will pop up with an audio ding about one to two minutes after you start driving. This warning cannot be removed nor the alarm silenced, but the road sign function works including detecting temporary speed restrictions from road works. It will remove the speed limit display from the navigation map, and replace it with the speed limits that it detected. The detected road signs show up on the AID as well.
    I suspect the warning has something to do with the road sign recognition function being programmed to recognise road signs complying with the EU regulations, and if the car is coded for any other regions it will display the warning stating that the functionality is restricted. In any case apart from the warning it works better than the navigation limits, since the Volkswagen Australian maps are at least 3 years out of date in some places and my estate shows up as offroad driving even though I have been in the current place for 3 yearss.
    Mods that Do Not Work
    1. Light Assist. I cannot get it to work on 132TSi with DAP/Luxury. Function most likely requires a separate headlight assembly. The xenon lights show up as BASIC, and there are quite a few other options that can be selected if the car is installed with it. The Highlines may be different.
    Still Trying to Figure Out
    1. Sunroof comfort closing. The 132TSi with sunroof does not have sunroof as an available adaptation parent channel in the central electronics. VW might have removed this due to safety reasons.
    Feb 2015
    Quote Originally Posted by Just_Westy View Post
    Long coding
    Then little button in top right (think it is second too left), will change screen.
    Then in top left hit Byte, type in 24 then select Bit.
    Jan 2014
    Narangba, QLD
    I tried to get this working and gave up when the sub menu's in my car didn't match the instructions. Same for Auto window closing in rain. I did get TMC and removal of the nag screen to work.
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
