Results 11 to 20 of 22
Thread: Traffic Sign Camera?
    Apr 2018
    Quote Originally Posted by Skoda729 View Post
    Long coding
    Then little button in top right (think it is second too left), will change screen.
    Then in top left hit Byte, type in 24 then select Bit.
    I got that thanks mate, actually I just forgot how to access the coding section at the time then realised later my mistake.
    Quote Originally Posted by Jondalar View Post
    I tried to get this working and gave up when the sub menu's in my car didn't match the instructions. Same for Auto window closing in rain. I did get TMC and removal of the nag screen to work.
    I got it to work fine following the instructions one of the sub menus isn't exact from memory is says traffic instead of road but it works with no error on startup anymore. The only thing I got is the restricted message whilst driving twice but given I havnt driven it a lot with it enabled not sure how often that happens. The speed limit is displayed along the top so it correctly recognises our signs.
    Passat Alltrack Wolfsburg Edition My18
    Apr 2018
    After driving for a few days with TSR on the messages have stopped and it works brilliantly.
    Jan 2014
    Narangba, QLD
    Good to hear Just_Westy, am I correct in assuming that when this is enabled it over rides the speed limits built into the GPS map?
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
    Apr 2018
    Not sure will check that out later I dont use the GPS unless I need it, it just puts a pic of the current speed limit next up above the gauges.
    Aug 2017
    Uk
    I think it uses GPS until it sees a sign which is different from the GPS
    Jan 2014
    Narangba, QLD
    I made some changes this morning but now the car says ACC disabled. How do you reboot the infotainment?
    Feb 2013
    Perth, WA
    Press and hold the power button for ~ 20 seconds
    But if it says ACC not available then you've possibly coded something wrong on your A5 FRT Sensor.
    MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
    MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
    Jan 2014
    Narangba, QLD
    Quote Originally Posted by Wynnston View Post
    Thanks, rebooting infotainment didn't fix it. I found that in the latest version OBDEleven under ACC there is a "Traffic sign recognition" active / not active, turning this on was what disabled ACC, probably needs something else activated as well. I did manage to code the not slowing when car in lane to right on ACC, window closing on rain and fan speed on auto showing on the climate control. Will have to try more later.
    Cheers,
    Karl
    Jan 2014
    Narangba, QLD
    Tried to enable the traffic sign recognition over the weekend using the instructions above but after 2 below there is no "Vehicle Functions", there is a Vehicle Settings but it has nothing about road signs. THere is stuff about road signs under ACC but when I turned on it disabled ACC. Similar when I tried to enable HBA, the Adaptation was there but then there is stuff about coding which just doesn't show for me. Using OBDEleven.
    Enable Dynamic Road Sign Display
    1. Go into Module 5F Information Electronics
    2. Select Adaptations, then Vehicle_Functions_List_BAP_Gen2
    Apr 2018
    At the top of the OBDeleven app screen is a small button you touch to access the coding. I'll check the vehicle functions list bap when I get home tonight.
