Traffic Sign Assist Activation
Select Control unit 5F (Information Electrical)
Adaptation
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Değer=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Değer=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
Değer=Active
Control unit A5 (front / advance camera)
Security access
Access Code 20103
Control unit Long Coding
Byte 1
Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
Select Control unit 17 (Dashboard)
Byte 5
Bit 2 Aktivate
Adaptation
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
Sent from my SM-G935F using Tapatalk
Pretty sure you’ll need VCDS for that
I completed DTSR with OBDEleven Pro.
You may also need to make sure the below is set;
Control Unit: A5
Adaptations: Road sign detection fusion mode: Road sign detection
This might help
Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
Previous - Passat 206TSI MY17 - Night Blue
This was in the Tiguan forums and worked for my Alltrack A guide to enable EU specific features for AU Spec Tiguans
1.Go into Module 5F Information Electronics
2.Select Adaptations, then Vehicle_Functions_List_BAP_Gen2
3.Select menu_display_road_sign_identification_0x21, and set to Enabled
4.Select Adaptions, Vehicle_Function_Adaptations_Gen2-menu
5.Select menu_display_road_sign_identification, set to Enabled
6.Select Coding, and then select Byte 24, activate Bit 6
7.Go into Module A5 - Front Sensor Driver Assistance
8.Select Coding, and then select Byte 16, activate Bit 4
9.Go into Module 17 Instruments
10.Select Coding, then Byte 5, active bit 2
11.Go back into Module A5 - Front Sensor Driver Assistance
12.Select Adaptations, then Road sign detection fusion mode, and change to Road Sign Detection. The original is Road Sign Fusion
13.Reboot the infotainment unit
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
You guys are juzt too good. Mine was a bit different but got there in the end. Mine has fusion , road and something called horizon to choose from. By the way no warning issues. Only bug is it dont know that its school holiday or outside of school times in 40km zones. Looks much bigger in life and super hd in real life in contrast to the pic. Thanks heaps peps.
Better shots
sorry wrong post
TRAFFIC SIGN RECOGNITION:
Multimedia (5F)
Car Function List BAP Gen2
Traffic sign recognition 0x21
Activated
Multimedia (5F)
Car Function Adaptations Gen2
Menu display road sign identification
Activated
Multimedia (5F)
Long Coding -> Byte 24 -> Bit 6 (activate)
Driver Assistance (A5)
Long Coding -> Byte 16 -> Bit 4 (activate)
Dashboard (17)
Long Coding -> Byte 5 -> Bit 2 (activate)
Road sign detection
Reboot the infotainment unit (hold power button until screen goes blank)
2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
2023 MY23 Nevada White Cupra Formentor VZx
2015 Carnival Yellow Honda S660
