Results 1 to 9 of 9
Thread: Traffic Sign Assist Activation
    Dec 2017
    QLD Australia
    Select Control unit 5F (Information Electrical)
    Adaptation
    Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
    Değer=Active
    Select channel (151) vehicle menu operation-menu_display_road_sign_identification
    Değer=Active
    Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
    Değer=Active
    Control unit A5 (front / advance camera)
    Security access
    Access Code 20103
    Control unit Long Coding
    Byte 1
    Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
    Select Control unit 17 (Dashboard)
    Byte 5
    Bit 2 Aktivate
    Adaptation
    Select : channel numbers indicate end of speed limit
    Importance to actively invest Show Valid suffix
    View Channel Valid suffix
    Corresponding value adjust default: 00100111
    Sent from my SM-G935F using Tapatalk
    Dec 2017
    QLD Australia
    Quote Originally Posted by Blackpaladin67 View Post
    Adaptation
    Değer=Active
    Değer=Active
    Değer=Active
    Security access
    Access Code 20103
    Byte 1
    Byte 5
    Bit 2 Aktivate
    Adaptation
    So i access this how from my obd11 pro ? A bit lost apologies for my lack of understanding.
    Mar 2014
    Melbourne, Vic
    Pretty sure you’ll need VCDS for that
    Sep 2017
    I completed DTSR with OBDEleven Pro.
    You may also need to make sure the below is set;
    Control Unit: A5
    Adaptations: Road sign detection fusion mode: Road sign detection
    This might help
    Mine - Mustang GT MY20 - Carbonised Grey - "Nicky"
    Hers - T-Roc 140 TSI Sport MY21 - Reveena Blue - "Rocky"
    Previous - Passat 206TSI MY17 - Night Blue
    Sep 2012
    This was in the Tiguan forums and worked for my Alltrack A guide to enable EU specific features for AU Spec Tiguans
    1.Go into Module 5F Information Electronics
    2.Select Adaptations, then Vehicle_Functions_List_BAP_Gen2
    3.Select menu_display_road_sign_identification_0x21, and set to Enabled
    4.Select Adaptions, Vehicle_Function_Adaptations_Gen2-menu
    5.Select menu_display_road_sign_identification, set to Enabled
    6.Select Coding, and then select Byte 24, activate Bit 6
    7.Go into Module A5 - Front Sensor Driver Assistance
    8.Select Coding, and then select Byte 16, activate Bit 4
    9.Go into Module 17 Instruments
    10.Select Coding, then Byte 5, active bit 2
    11.Go back into Module A5 - Front Sensor Driver Assistance
    12.Select Adaptations, then Road sign detection fusion mode, and change to Road Sign Detection. The original is Road Sign Fusion
    13.Reboot the infotainment unit
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
    Dec 2017
    QLD Australia
    You guys are juzt too good. Mine was a bit different but got there in the end. Mine has fusion , road and something called horizon to choose from. By the way no warning issues. Only bug is it dont know that its school holiday or outside of school times in 40km zones. Looks much bigger in life and super hd in real life in contrast to the pic. Thanks heaps peps.
    Dec 2017
    QLD Australia
    Better shots
    Oct 2021
    sorry wrong post
    Blackburn South, Victoria
    TRAFFIC SIGN RECOGNITION:
    Multimedia (5F)
    Car Function List BAP Gen2
    Traffic sign recognition 0x21
    Activated
    Multimedia (5F)
    Car Function Adaptations Gen2
    Menu display road sign identification
    Activated
    Multimedia (5F)
    Long Coding -> Byte 24 -> Bit 6 (activate)
    Driver Assistance (A5)
    Long Coding -> Byte 16 -> Bit 4 (activate)
    Dashboard (17)
    Long Coding -> Byte 5 -> Bit 2 (activate)
    Road sign detection
    Reboot the infotainment unit (hold power button until screen goes blank)
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
