Originally Posted by
Rocket36
Um that's because it is! Are you saying that's not how it is in Australia? I mean it's fairly basic engineering to get a trailer to be evenly balanced when it's horizontal to the ground (single or double axle) to the point where you shouldn't need to put the jockey wheel down on double axles. Then when you hitch it up, you make the necessary adjustments to the hitch setup to two horizontally. The tow car should be pulling, not holding one end off the ground.
Hmm you obviously arent up to speed with towing dynamics are you If you have no weight on the ball the van is subject to sway and yaw and that very fact got three people killed a few years ago
Read this and learn Jong Coronial Report.rtf - Google Drive
and this perfectly tells you why your theory is wrong
Watch this video and you may understand
YouTube
What SHOULD be and what needs to be are two different things
