Results 1 to 10 of 20
Thread: Suspension upgrades & custom valves exhaust
    Hello all, long time reader but first time poster.
    Have had a history of MKV R32s, MK6 Rs and now a 2021 Passat B8 206tsi.
    This is a stage 3 car with all the supporting mods with the smaller of the Garrett powermax turbos retaining a similar spool to the factory turbo. Has been dyno’d at 280kw atw.
    Anyway, a couple of questions. Have been looking at exhausts for a long time so ended up buying a valvetronic dual muffler set up, but I need some custom work done anyone have any recommendations. I am in Melbourne’s NW area.
    Also I am looking at getting bilstein shocks. I have the eibach pro springs with super pro rear sway bar with end links, but I believe the suspension is getting squeaky from all the speed humps around my area. Does anyone have any experience or feedback for me, is the squeaks coming from the shocks? Or is it something else
    For shocks I am looking at the bilstein B8s, car has only done less than 40,000kms
    Thanks guys!
    The squeaks will be coming from the strut top bearings - my Mk7 Golf GTI had creaks when going over bumps with only 40,000km on it and when I replaced the strut bearings (also replaced the strut mounts for good measure) it was nice and quiet again. Its very common on the VW's.
    These are the parts im talking about - note these are the parts for a Golf.....not sure if the Passat uses the same ones or not.
    Strut bearings
    SACHS Strut Bearing '-' VW Golf Mk7 GTI/R & Audi 8V A3/S3 | AutoInstruct
    Strut mounts
    SACHS Strut Mount '-' VW Golf Mk7 GTI/R & Audi 8V A3/S3 | AutoInstruct
    As for your exhaust, looks like there are several very good options in Melbourne. Depends on your location and budget I suppose. The price can vary greatly based on....
    Material used (mild steel = cheap, stainless steel = expensive)
    Bends - press bends = cheap/crap vs mandrel bends = good/much better flow but more expensive
    Welding method - mig welding = quick and cheap but looks terrible vs tig welding which looks great but is slower and more expensive
    Joins - basic flanges or v bands
    - Hitech exhaust in Carrum Downs
    - Exhaust world in North Melbourne
    - Performance exhaust nationwide in Knoxville
    - Extreme exhaust in Sunshine
    - Classic Custom Exhaust in Coburg
    etc etc etc the list goes on
    Google Search for Custom Exhaust Melbourne
    Thanks Lucas_R.
    Interesting that the likely culprits are the strut mounts and bearings. Is this labour intensive and a quick Google shows some 034 heavier duty items - is it better that I get these so I don’t have to change them every 40,000kms.
    I did ring Exhaust World and Hi tech. I don’t think Hi tech bothers with the valved units but they do some good custom work but pricey.
    Exhaust world use mild steel and then they heat coat it in black which is not ideal, but right now I’m just after the tone as the performance is enough anyway so I might end up going with Exhaust world as they are reasonably priced and do the valved unit install too.
    Can’t wait for it to sound decent. I have a scorpion downpipe, custom mid pipe and res delete and with the standard mufflers it rattles so bad that it sounds like the exhaust is going to fall off!
    Aug 2021
    034 strut mounts/bearings have a mixed reputation, along with their engine mounts. I have no personal experience though so it's only hearsay.
    The large circular rearmost bushes in the lower control arms are also contributors to noise - a well-known issue and VWAG have published multiple TSBs on how to treat these with a special lithium grease to stop them from binding and creating noise. My Passat suffered from binding bushes not long after I bought it second-hand, and the noises were horrible.
    Interested to see how you go with your noises. My front end is still decidedly loose-feeling at times. I foresee new lower control arms and strut mounts/bearings in my near future.
    I would not recommend the 034 mounts/bearings. I installed those on my Golf and they rattled like hell……every.single.bump. Checked everything was tight several times but its just how they were - no thanks!!! Not for me.
    Replaced them with the Sachs units linked above and they were like brand new again.
    Its a 1hr job for a mechanic with a hoist and tools. Try TTY euro in Mordialloc if you are anywhere near that area.
    As for exhaust - your factory exhaust is approx 2.5” diameter mandrel bent stainless steel, so if you want improved flow (probably necessary with your power level) then it needs to be better than this. So 3” mandrel bent at least. You can go for mild steel if budget doesn’t allow, but make sure it gets painted with black heat resistant paint to prevent/slow down rust.
    Thanks guys. I will stick to the Sachs units. Sounds like they work a treat.
    Another query. For a stage 3 car I am sure that the service guys have been using 5W30 oil, but thinking now that the car has done almost 40,000kms I might be better served using some motul 5W40 oil, think it’s 8100.
    Given all the work done to the car I’ll likely keep it for another 2 years unless the cupra Leon sportstourer tempts me in a year’s time.
    Alright got the car back from the workshop. The creaking noise is coming from the suspension, they are saying it is the bushes from the control arms from both front and rear. So kinda a similar problem to the strut bearings, it must be those rubber mounts/bushes are horrible.
    The front one is starting to split under the load from the stiffer suspension and it makes me think that the Passat suspension parts are far inferior to the golf r as it’s meant to ride more as a family car - which is understandable.
    On a different note, they are looking to measure up the custom exhaust so i am excited but also wary of the cost.
    Aug 2021
    Quote Originally Posted by GT2260s View Post
    No, they are the exact same bushing material in the Golf R vs the Passat. Different bushes were used in some Audi models, and the Mk8 Golf has updated bushings.
    You can apply a liberal application of silicone spray lubricant to those bushes, ensuring it penetrates as much as possible around the openings and interfaces of the bushes vs the suspension arms and crossmembers. This will tend to quieten things down a bit. I gave mine a spray a few weekends ago and the difference it makes to noise and the overall feel of the front end is quite significant. I need to do the rears soon.
    I am thinking of getting the superpro bushes for the control arms front and rear. I already have a superpro rear sway bar and end links so it makes sense for me to go the same route? Anyone have any experience or recommendations with this?
    I guess I just want to fix it and set and forget if that’s possible.
    Aug 2021
    Personally I'd steer away from poly bushes for the rear-most lower control arm bushes. Good info here (noting of course than any of the aftermarket Golf lower control arms won't fit the Passat, so you're limited to press-in replacement bushing assemblies only).
    I'm likely to go down the path of fitting OEM Audi bushings with smaller voids myself.
    Front LCA bushing options | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
