Results 1 to 10 of 12
Thread: Surprise under engine cover
    Mar 2017
    Tasmania
    So yesterday afternoon I lifted the engine cover on the Alltrack as I was looking at the connections used for the crankcase breather. Thinking about catch cans and all that...
    Anyway, one of the reasons i was thinking of a catch can was to stop the Intercooler becoming an oil trap.
    so wasn’t I surprised to discover that the 140TDI has a water to air Intercooler, which is an integral part of the intake manifold! The angle it’s mounted at makes it impossible for any oil to build up in the Intercooler. The issue of oil mist mixing with egr gasses remains however, so a catch can is still on the list as a possibility.
    i wonder what other little surprises these things will present me with in future.
    Apr 2018
    If it's not building up in the intercooler I assume it's going into the intake manifold ?
    Mar 2017
    Tasmania
    Logic says yes. Hopefully being combusted without too much egr particulate mixing with it first, and setting into a nice crust inside the valve runners...
    Mar 2017
    Tasmania
    My surprise was that it was a high-mounted water-to-air intercooler, not a conventional front-mounted air-to-air intercooler.
    Apr 2018
    Quote Originally Posted by doc_777 View Post
    I never even bothered to check and just assumed it was air to air.
    Passat Alltrack Wolfsburg Edition My18
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Just_Westy View Post
    So did i was a big surprise to me 2 was thinking about a intercooler upgrade lol that put the nix on that good news is that the water/air intercooler is good for any power upgrade you want to do unless you go crazy
    As far as egr is concerned i will be getting a clean done on intake/maf sensor every 2 years( about 45k) to limit build up as i intend to keep car for a long time
    Don't know what i will do when dfp eventually craps out tho
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Mar 2017
    Tasmania
    I think the DPF is one of those things that, when it eventually dies, will be simply an expensive maintenance item.
    I was looking this morning at the short crankcase breather pipe. Wondering if something as simple as a gravity loop of hose would stop a LOT of the oil. Won’t stop as much as as a catch can, but will do a decent job I reckon.
    i do like your idea of cleaning the manifold every couple/few years. I’ll admit - I haven’t yet investigated the EGR routing. Depending on where the recirculated exhaust gas enters the intake charge, will determine where any buildup will start to occur... (will go out and poke my head under the bonnet now before it starts raining down here.....will report back my results)
    Do do you know of any sites like REALOEM - their BMW parts diagrams are brilliant - show the full breakdown and assembly basics.
    im not sure how long I’ll have this car for. Being the only one in Tassie (Alltrack Wolfsburg in Crimson Red) i’m inclined to keep it for novelty value if nothing else. I want to buy my wife an M2 before they cease production in ~2020. I don’t reckon you’ll get something quite as cool as a twin turbo 6 in a car the size of a 2 series coupe in years to come. I think however that the Alltrack would make a very comfortable, useful second vehicle if we upgrade her b8 comfortline sedan to an M2.
    Apr 2017
    belgrave victoria
    Yeah i think the alltracks will be held onto by a lot of owners they just drive so nice
    Mar 2017
    Tasmania
    K...so the diagrams at Volkswagen > VAG ETKA Online > Nemiga.com are ok. Not as easy to navigate as realoem, but tolerable none the less. You do need to know what engine types are applicable when getting into some of the specifics, because different configurations have vastly different hardware setups within the same engine family,
    anyway, what have I learned about egr on the 140TDI in the Alltrack...the egr cooler is around the bac kid the engine right next to the turbo. All good. Cooled gasses are then directed around to the egr valve, which is on the side of the intake manifold. So the major buildup of carbon from recirculated exhaust gas mixing with oil mist from crankcase ventilation will be in the intake ports. Due to heat cycling, and gas velocities, I don’t think it will build up much at all (unlike buildup which occurs in intake manifolds, where the egr is at the start of the intake manifold).
    air mass sensor is right up behind the air filter housing. If it ever gets an oil coating, there is something drastically wrong.
    Mar 2017
    Tasmania
