Current: MY16 132TSI | Luxury | R-Line
MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
There should be 4 drain holes locate at each corner of the roof . 2 of them are visible located at the front coroners of the drain rails when you open the sunroof .
I test it by squirting some water into the drain rails to see if the water drain through out to the sewage around the side front door (when you open them)
One of mine was blocked by the debris (leafs ,pollen, plants, etc) hence the back flow cause an internal leakage along the A-pillar
Audi A4 B9(8W) AVANT Quattro 2.0 TFSI
SOLD - Skoda 2012(MY12) 125 Tdi Superb Wagon, KESSY, Power tailgate, Panoramic Sunroof
To be honest, I regret repairing the sunroof noise. The noise went away for about 3 weeks, then it came back worse... It is being checked again because they have my car to replace the gearbox. I think if you have a bit of noise and you can ignore, do that.
Sent from my LG-H990 using Tapatalk
seriously...haha, most of the times, the noise is there if it's a hot day. I'd tilt the sunroof just to get rid of the noise. VW Waitara said there is a new tpi for the sunroof which also include a lubricant (not sure a different kind of lubricant or not).
I suspect the noise is because the back end of the sunroof base is made from some kind of flex material which expands when it's hot.
