No noise on mine, regardless of how it is opened or closed.
Has anyone experience rattle noise coming from the sunroof? I have MY16 passat and I hear rattle/squeaky from the sunroof every time it is closed and tilted. When I fully open it, I hear it a lot less. Dealer has put lube around the sunroof but it doesn't fix the noise at all.
Yep - had the same problem with my MY16 140TDI Highline sedan with R-Line and Luxury Packs. Drove me batty!
There's a reason why my current 206TSI sedan doesn't have a sunroof!
I read about this issue on various forums and its seems most B8 Passats are fine, but there seems to be a batch with rather dodgy sunroofs. Your dealer should know about it and using lube will be no help whatsover. Push to get it fixed properly under warranty.
I have the same issue with my Superb 206 sedan.
I have noticed it gets much worse if I leave my car a bit under the sun.
The dealership looked at briefly, "cleaned and lubricated" the sunroof, didn't make any difference. I will need to find some time to drop it and ask them to fix it properly.
I've got this annoying issue when the car is on an uneven surface the roof creeks and groans a bit. Nothing to major but makes me cringe as I've had a couple of mates with 7R's have their sunroof pop/explode most likely due to being installed/aligned incorrectly at the factory.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
I get creeks also on uneven surface (going up a driveway) on MY16 R-Line. I think the creaking is quiet normal on the R-Line cars due to some body flex with sunroof and stiffer suspension combination. I also get a knock/rattle coming from the rear roof area when driving on rough uneven roads. I'm beginning to think the knock might be caused by the sunshade roller or sunroof cables in the roof. I haven't had it looked at as yet but don't really want the dealer removing the roof lining.
Although I never had any rattles, VW are replacing the inner rubber seal on mine as it no longer sits flush. This is the inner rubber when the sunroof is raised up (not any external rubbers). Will wait for the part to arrive and report back.
Dealer changed the securing bolt on my sunroof and put some more lubricant. Guess what, rattle noise is the same as before. When the sunroof close, I hear more like squeaking but if I tilt the sunroof, I can easily hear the rattle. When the sunroof is fully open, I hardly hear anything though.
Has anyone got the same issue and able to fix it?
