Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 74
Thread: Sunroof rattle noise
  1. #61
    Jan 2019
    Parramatta, NSW
    i had rattling noise from sunroof, when going over rough/bad/coarse surface.
    VW Denlo Parramatta (NSW) was able to fix it - has been a month. will report if something changes.
    I was told there is an existing TPI on it - all it needs is some extra felt strips.
    In the process, they soiled my roof linings while initially checking for the fault - took it back and was cleaned.
    Again, when the actual repair work was done, they damaged my rooflining tearing it for 1.5 inch.
    Have complained to them and waiting for a date to fix it.
    MY18 Passat Comfortline 132
  2. #62
    Apr 2017
    Quote Originally Posted by maddykartik View Post
    My sunroof was fixed months ago however i did not notice any damages.
    Would you take some photos and maybe there were some places damaged i did not notice?
    My Car was fixed by a TPI as well. I can still hear the rubbers friction but no knocking sound anymore.
    THanks
  3. #63
    Feb 2017
    My car is scheduled in 3 weeks to do the tpi of changing the inner frame. Fingers crossed.
    Current: MY16 132TSI | Luxury | R-Line
    MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
    MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
  4. #64
    Feb 2017
    Apparently, dealer is doing 60D6 - roof frame recall on my sunroof (not TPI). Maybe it will fix the rattle.
  5. #65
    Apr 2017
    Quote Originally Posted by rave75 View Post
    Interesting. My passat was serviced last month with no recalls on it.
  6. #66
    Apr 2017
    Further, I checked 60D6 recall. Volkswagen Group Australia Pty Ltd — Volkswagen Passat and Arteon MY2016-MY2018 | Product Safety Australia
    Only 14 passats + some Arteons on it. Lucky you.
  7. #67
    Apr 2017
    However, I feel my passat did have the symptom described. The panel detached from the trim and started to knock on each other.
    That's why I was hearing loud knocking sounds.
  8. #68
    Feb 2017
    Quote Originally Posted by zzc2010 View Post
    Really?! I thought the recall is for Passat which panel has been replaced before as well?. Anyway VW didn't contact me about the recall, it was when I brought my car and demanded for it to be fixed (again) that they said "oh there is a recall for it, might fix the noise."
  9. #69
    Apr 2017
    Good job. Might fix the noise. LoL
    If mine got the noises coming back, I will ask them to do this recall or probably they already did what the recall says.
    No idea.
  10. #70
    Feb 2017
    Just got the car back. Still has the rubbing noise on the front part of the sunroof, it is less noisy than before but still annoying though. That was the 9th time I went to McCarrols.
    The rubbing from the headliner is gone now. I guess they didn't property put back the headliner properly before.
