I have finally got the car back... They installed a new revised sunroof... So far so good. I'm hoping the noise won't come back in the future.
Sent from my LG-H990 using Tapatalk
Hi,
I have the same issue with my Passat 140TDI sunroof. It is squeaking while driving and as soon as you open it it will start creaking. Very annoying. My dealer tried to lubricate and tight some bolts in the sunroof, but the issue is still present. Not sure what to do at this stage...
If I were you, I'd try to live with it. I don't think it can be fixed at all. Mine was fixed twice with many new "revised" parts. The noise always comes back. It is not worth ripping sunroof apart. Lubricating won't fix the problem either.
Did the noise come back?
Mine was silent for a week and then the back part creaks again when it's hot. Only creaks when I have it fully closed. I also now have slight squeaks from the headliner above my head. FFS.
One thing to note, when I had my A class, I could visibly tell that the railing were lubricated, it was greasy. With Passat, I don't seem to see a lubricated part at all?
Current: MY16 132TSI | Luxury | R-Line
MY14 C250 W205 | Command | Vision | Exclusive | Seat Comfort
MY13 A200 W176 | Command | Vision | Exclusive | Seat Comfort
Yes the noise is back... The car was at the dealership for weeks and the problem hasn't been resolved. Not only that, but now if I open the sunroof and then close it, the sunroof slides in to close, then tilts open immediately. I have to try to close around 10 times for it to close.
I'm sick of visiting the dealership, and I'm sure they won't be very happy to see me again.
Hey Vexed,
I had an issue with my sunroof not opening/closing & then opening straight away. The dealer replaced the switch which fixed the issue. That was around 6 weeks ago & all good since.
