Are you meeting the pre-requisits for it to work?
Engine at operating temperature, sufficient brake pedal pressure, that sort of thing.
Hi
My 132 TSI Comfortline only operate start stop for one day since I picked it up.
Is it normal?
Hows your Passat start stop system working?
Please
Neal
'07 Transporter 1.9 TDI
'01 Beetle 2.0
It doesn't usually care about engine operating temp, well mine didn't anyway. Best way to tell is to hit the "Car" button on your infotainment unit until a picture of your car pops up. There should be an (a) Start Stop (or something like that) button. This will display the status of the start stop system.
MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
Mine doesnt stop unless the brakes are on firmly. Then I lift off a bit and engine starts to allow a timely getaway from the lights.
No good if you just hold brakes on gently
There is a sensor on the brake master cylinder that measures pedal travel.
If insufficient pedal pressure is applied, it won't work.
'01 Beetle 2.0
I do understand the pressure on the brake affecting the operation of start stop system.
The thing is that the info presented on the screen is always "power consumption is high".
The last time my old Golf did it. Its battery broke and cost me 500 to fix it.
It's a new Passat and I don't want to have the same issue again.
Take it back and tell the dealer to work it out.
I will definitely if things not working out in the next week.
