40PSI will reduce the contact patch, and increase wear through the middle of the tread face. Sure, it will help the edges wear better, but you won't be doing your traction any favours.
Load inflation tables are your friend. The whole tyre manufacturing industry uses the same references, so it doesn't matter which table you use - but recommended pressures exist for a reason.
Here's an example table:
https://toyo-arhxo0vh6d1oh9i0c.stack...s_20170203.pdf
My Alltrack runs 245/40-19. Tare weight is 1671kg, and for the sake of simplicity lets say its evenly distributed across both axles. That equates to 3676lbs (only did that conversion because I am using an american load inflation table).
At 40PSI the tyre carcass is rated to 1600lbs PER TYRE!
To each their own - and if you want to run high pressures then so be it - but getting some extra kays out of your tyres by increasing the pressure is not necessarily a brilliant thing to do. You've substantially reduced the contact patch which dramatically reduces the traction profile of the tyre.
