You pretty much just shim up the low part in the boot, as someone who slept in my Bora a few times, it works for 1-2 nights while on a road trip. I would not recommend it long term![]()
Hey everyone,
I’m considering the option of sleeping in the back of my 2018 Passat Alltrack for road trips and long drives. I’ve done this before in my Touareg and later in my 5 Series, both of which worked well—the Touareg’s rear seats folded almost flat, while the 5 Series had a completely flat and lockable locked in place.
I’m new to the Passat world and I just noticed that the rear seats not only don’t fold flat but also create a noticeable step-up where they meet the boot. This makes it tricky to get a level sleeping surface. I’ve come across a company in Europe that sells a solution for this, but it costs a few thousand dollars, which is way out of my budget. So, I’m wondering—has anyone here found a way to level the boot and maybe put a mattress in it?
Any tips, modifications, or workarounds would be greatly appreciated!
TIA
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
As above, the cheap solution would be to build a raised false floor out of plywood which you can place in the boot to level the boot and rear seat. Then slide a matress of some kind in to sleep on.
I’ve done this a few times in my b6 Passat wagon and b8 Passat wagon. You may need to push the front seats forward and take off all rear headrests. I believe there is still a very slight incline but at least your head is higher than your legs. Maybe prop a pillow or towel under feet to level yourself out. Best practice is to inflate the air mattress or whatever you’re using while it is inside the vehicle - see photos while I was camping for a few days
2018 B8 Black 206TSi Estate - Thule Roof Racks - Tow bar - Dechrome - REVO Stg1 ECU/TCU - R600 Intake - CTS turbo muffler delete - CTS inlet pipe - CTS 200 cell catted downpipe w/ OEM resonator delete
2009 B6 Black 2.0TSi Estate
Follow my instagram for the build @rogs_passatb8 (if... you wanna...)
