Results 1 to 4 of 4
Thread: Side mirror dip malfunction
    Apr 2013
    I regularly use the passenger-side mirror dip for kerbside parking. I know I need to have the side mirror adjustment knob left on the L (left) setting for this to work.
    Recently it’s stopped returning to the normal position after being dipped. Eg: I put the car in reverse, the mirror dips, I then put the car in drive and it doesn’t come back up at all (even after a few minutes in drive).
    The only solution is to readjust the mirror back up manually using the joystick on the driver’s side door.
    It’s not consistently doing it so I suspect the dealer won’t be able to replicate (gremlins law?).
    Occasionally it’s become so confused that the settings have flipped. I never realised how disconcerting it was driving without a left side mirror until this happened and all I could see was road.
    Has anyone experienced this? Any suggestions?
    The car is a MY19 206tsi. Folding on locking and manual adjustment works fine.
    MY14 MK VII GTI | Pure White | Manual | Bi-Xenons (his)
    MY19 B8 Passat 206TSI wagon | Manganese Grey (hers)
    Pacific Paradise QLD
    Is the battery down a bit Passats do funny things when it is Mine used to get dash full of lights if it was down too far
    May 2019
    Sydney NSW
    Hi all,
    Not sure if I should of created a new post but I'm trying to figure out whether or not my 2015 B8 MY16 Passat Highline has the side mirror dip feature? I went into the maneuvering and parking system and couldn't find anything.
    Cheers,
    J
    Should tell you in the manual how to do it Try that and see if it works
