Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: RE: 140TDI DPF with Adblue
  1. #21
    Question about DPF: If you are not aware that your car is on a regen until you turn it off and the fans are howling. Are you better to restart and go for a drive or leave it be?
  2. #22
    Car has done 2 regens in no more then 600km is this normal also both regens I am aware of have been when car has turned off?
    Think I am getting paranoid.
  3. #23
    Pacific Paradise QLD
    Yes i think so. Had mine for 6 years Wouldnt have a clue when its done a regen and as long as it keeps going correctly I dont really care
  4. #24
    Feb 2015
    Quote Originally Posted by Asahi1985 View Post
    Here is what appears to be some answers from VW tech support around DPF's I have found on a UK site. Maybe this will help, applies to all dpf engines.
    DPF Regeneration Information - Must read for all drivers of DPF equipped cars - MkV (Mk5) Golf, Golf Plus & Jetta - uk-mkivs
    Sent from my HTC_PN071 using Tapatalk
    MY15 TIGUAN 130TDI R-LINE - Pepper Grey, Panoramic Sunroof
  5. #25
    May 2007
    Took the car to VW today and was advised that the DPF is fine, no build up what so ever. Must have just been me not being firm enough on the brake pedal as described earlier...
  6. #26
    May 2007
    Had the AdBlue topped up whilst getting the 12mth / 15,000km service today (only 5,000kms on the ODO).
    The AdBlue info has been reset and now displays 10,000kms range.
  7. #27
    May 2007
    Here is some info from the Volkswagen UK site; http://www.volkswagen.co.uk/technology/diesel/adblue
    Interesting info regarding the AdBlue Capacity; 13 Litres (approximately)
    1.89L Top Up Bottle (with Adaptor) VW Part No. G052910A2
    I have tried searching but can't find a clear answer...
    Can you "top up" the AdBlue at anytime?
    Or do you have to do a complete "refill" when the first warning message appears?
    Also, has anyone used an AdBlue bowser at a petrol station yet? Are they high flow nozzles or are they suitable for light vehicle applications?
  8. #28
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by ope126 View Post
    Suitable for light vehicles, flow rate is no difference to a standard fuel pump. Some require a magnetic adapter applied to the end to allow for liquid flow, this is normally with the cashier. You will tell if there is nothing happening at the pump.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  9. #29
    Apr 2017
    belgrave victoria
    Also as a warning do not do a whoops put adblue in fuel tank this is even worse and more expensive that putting petrol in a diesel
    at my work (am a heavy truck driver) several drivers have done this and ruined a motor to the tune of 80k! this includes total engine rebuild and compleate replacement of fuel system from tank all the way to injectors its bad ju-ju vry corrosive
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
  10. #30
    Mar 2017
    Tasmania
    <snip>
    <snip>
    Yes.
    You can pay a small amount at the dealers service dept, or you can fill at any fuel shop* that sells it. It's cheap stuff - pump price is around a buck a litre. I would buy from the dealer as it comes from sealed containers.
    *I don't use the name "service station" anymore - no 'service' at any of them.....they are just fuel retailers these days.
